Pocket GPS World :: View topic - Install fails with TT3 on Viewsonic, just freezes device.
ikesler
PostPosted: Thu Dec 09, 2004 10:29 pm    Post subject: Reply with quote
Well I tried to install the voice files from the disc with no success. It says none were loaded.
Also I have no TT on the today screen and a different icon in the start menu......... does that matter?
Ian
PostPosted: Thu Dec 09, 2004 11:07 pm    Post subject: Reply with quote
Yes, voices are separate - you can install the ones from the CD
ikesler
PostPosted: Thu Dec 09, 2004 11:34 pm    Post subject: Reply with quote
I have tried installing the voices from the disc 5 times with no success...... for some reason when I lauch the app it says NO VOICES are installed....... but I see them in my remove programs option on the device. Perhaps it doesn't recognize the installation that I have because it isn't from the cd?
Ian
PostPosted: Fri Dec 10, 2004 12:30 am    Post subject: Reply with quote
Not all is lost. Have a look at my article wher I describe the required registry settings.
How did the activation go?
ikesler
PostPosted: Fri Dec 10, 2004 1:49 am    Post subject: Reply with quote
activated fine....... it just doesn't find the voice files...........
Ian
PostPosted: Fri Dec 10, 2004 1:52 am    Post subject: Reply with quote
Have you checked the registry as described in the article?
ikesler
PostPosted: Fri Dec 10, 2004 1:56 am    Post subject: Reply with quote
where do I find it?
Ian
PostPosted: Fri Dec 10, 2004 2:11 am    Post subject: Reply with quote
http://pocketgpsworld.com/tomtom-navigator-registry-hack.php
ikesler
PostPosted: Fri Dec 10, 2004 2:27 am    Post subject: Reply with quote
Well I did find it a little bit ago and tried it......... couple problems.... I have no Voice folder. I created one and put the 2 voice files into it, but I cannot see it in the registry. I have TT loaded all over my device it seems,
Program Files/Navigator
MyDevice/Tom Tom
My Docs/TomTom Navigator
Windows/ a bunch of files
It is very difficult to figure what goes where......... but I do not have a voice folder anywhere.
Ideas?
Thanks sooooo much for the time on this one!
Ian
ikesler
PostPosted: Fri Dec 10, 2004 2:33 am    Post subject: Reply with quote
fyi
The only folder I have in that Tom Tom folder in the picture is a Maps folder....... no Voice.
If I create one I still can't see it.
Ian
PostPosted: Fri Dec 10, 2004 7:05 am    Post subject: Reply with quote
Again, let's do this slowly
You need to perform two steps
1) install the voice CAB and note down into what directory it installed. For example, I manually installed mine into \Storage Card\Navigator\USAC (for USA Computer Voice)
2) using a registry editor, verify that the following branch exists
\HKCU\Software\TomTom\TomTom Navigator\Voice
If not, create the key.
Then verifiy that within this key there is a string value called LastInstalled that points to the location where you installed your voice file to.
ikesler
PostPosted: Fri Dec 10, 2004 8:14 pm    Post subject: Reply with quote
Thanks for your patience! Smile
Here is the thing...... I can't find a voice CAB file. I can only load from the cd itself it seems.
Is that a problem or am I missing something?
Ian
ikesler
PostPosted: Fri Dec 10, 2004 8:18 pm    Post subject: Reply with quote
I also noticed that it isn't the full new version I don't think. The screenshots from their website and the reviews are different than what is running on my device a little....... I have the new icons. But when in 3D view there is no street names showing....... also when in Navi mode I have the old bottom portion, not the new one
I don't have this.......
I have the one with the old bottom.
I also don't have the new TT logo on the today screen, or in the Programs list..... I have the old logo in the list.
Is it different because I am in the US? Or did the install not go correctly?
thanks much!
Ian
ikesler
PostPosted: Fri Dec 10, 2004 9:43 pm    Post subject: Reply with quote
I also have the old Map view...........
Not this one......
also...... don't have this
I have the old properties type menu. Black writting on white text.
The only thing that seems different are the large icons from the previous version I had.
Ian
PostPosted: Fri Dec 10, 2004 10:28 pm    Post subject: Reply with quote
You are installing TomTom Navigator 3. The screenshots you show are from TomTom Navigator 4 (or 2004, as they call it). I did warn you before that TTN3 will be of not much use to you if you only have the 2.24 maps.
As for the voice files
- find the CAB on the CD, or get one from the web
- copy it to the Pocket PC
- run it
- then verify the registry and adjust it if necessary.
Page 2 of 3
