Pocket GPS World :: View topic - pinouts for gps to RJ11 plug?
Surya
PostPosted: Fri May 28, 2004 11:00 pm    Post subject: pinouts for gps to RJ11 plug? Reply with quote
Anyone know what the normal cable connections are for a gps mouse to a rj11 plug are?
Pc-Mobile
PostPosted: Sat May 29, 2004 3:10 pm    Post subject: Reply with quote
It is not universal !!
Every manufacturer use different pin-outs.
RJ11 is used only because it is cheap and readily available but it is not like a say, 13amp plug that you must put which pin to which.
You are out of luck here unless you find someone who has the same systems as yours and is a competant/knowledgeable DIYer and willing to share the information with you.
Pc-Mobile
http://pc-mobile.net/gps.htm
Surya
PostPosted: Sat May 29, 2004 3:22 pm    Post subject: Reply with quote
I understood that there was a defacto standard emerging?
If not, do you know what the pinouts used by Tomtom are?
Unfortunately I'm dealing with the input side, not the gps output, otherwise it would only take a moment to work it out.
Surya
Pc-Mobile
PostPosted: Sun May 30, 2004 3:43 am    Post subject: Reply with quote
We have no knowledge of it.
So it has to come from "someone who has the same systems as yours and is a competant/knowledgeable DIYer and willing to share the information with you."
Pc-Mobile
Surya
PostPosted: Sun May 30, 2004 8:28 pm    Post subject: Reply with quote
OK, I got my meter out and sorted it myself thanks.
If anyone may be interested the following works for me:-
RJ11 4 wire, numbering from the left looking from the back of the plug with the clip at the top:-
X
1, +V power to GPS
2, RX, data from GPS
3, TX, data to GPS
4, Common ground
X
Surya
Pc-Mobile
PostPosted: Mon May 31, 2004 3:25 am    Post subject: Reply with quote
So it is easy!
That's what you should have done in the first place.
Pc-Mobile
Surya
PostPosted: Mon May 31, 2004 10:36 am    Post subject: Reply with quote
I don't believe in re-inventing the wheel!
AlanS
PostPosted: Sat Sep 04, 2004 2:48 pm    Post subject: Reply with quote
That doesn't seem analogous to re-inventing the wheel, that's far too complex a task.
It seems more like having a marketing envelope in front of you addressed to 'The Occupier' and asking your neighbour what is in his letter because it's too much effort for you to open the envelope.
When the guy can't tell you you then open the envelope yourself.
mnazar
PostPosted: Thu Dec 09, 2004 4:09 pm    Post subject: Reply with quote
I would like to ask you if you dont mind. Thire ar six pinouts on the GPS reciver You have explained about 4 wires. What about the other tow please and you did not mention about which side should we start counting from clock wise or anti clock wise. Please help I got same saution here.. Please please help.
Thank you
MNazar
X
1, +V power to GPS
3, TX, data to GPS
4, Common ground
X
Surya
8O
Pc-Mobile
PostPosted: Fri Dec 10, 2004 5:06 pm    Post subject: Reply with quote
Every make of GPS has different pin-outs.
Surya did not say what his GPS was.
You did not say what your GPS is.
The chance of getting your GPS to work with his pin-outs is really very small.
If I were you, I would consult the GPS manufacturer (may be in the manual) rather than wasting your time.
Pc-Mobile
22.064 (26 Jun 24)
