EFC Occasional Visitor
Posted: Tue Nov 30, 2004 11:52 pm Post subject: * New Camera Database * Camera .bmp Not Showing Correctly |
Since updating to the new camera database, all the camera .bmp files are showing as distored yellow and black squiggles except for the temp cams.
Any ideas ? |
Dave Frequent Visitor
Posted: Wed Dec 01, 2004 12:11 am Post subject: |
The GATSO and MOBILE BMP's are displaying fine on mine on TTN3, so I think you've probably corrupted the images when you've extracted them from the ZIP file or perhaps you've undocked/ejected the SD card before it had completed writing to the card ? |
Posted: Wed Dec 01, 2004 12:21 am Post subject: |
I can open the .bmp under windows ok, they just are not showing up correctly on the device.
I have deleted and reloaded a couple of times, I will try deleting and re-downloading the file to see if that helps.
Cheers |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Wed Dec 01, 2004 12:34 am Post subject: |
It's not a corrupted file, as it happens to me, too. I mentioned it to Oldie earlier. As a workaround, I've extracted the .bmp files from the previous release over the newer ones and used those. I wonder if the file size or colour depth has something to do with it. Perhaps we're limited to a 1Kb picture? I'll try and find out in the morning. _________________ Tim |
Oldie Pocket GPS Moderator
Joined: 22/11/2002 13:33:48 Posts: 992 Location: Surrey, UK
Posted: Wed Dec 01, 2004 7:21 am Post subject: |
I do not know what the problem is with the latest bitmaps as they work fine on my TT3 iPAQ 3970 running PPC 2002.
The bitmaps were created with 8 bit (256) colour so that TomTom Go users would not have any problems( I hope that they don't). Usually icons using few colours work without a problem.
Richard |
Posted: Wed Dec 01, 2004 10:13 am Post subject: |
Tim Buxton wrote: | It's not a corrupted file, as it happens to me, too. I mentioned it to Oldie earlier. As a workaround, I've extracted the .bmp files from the previous release over the newer ones and used those. I wonder if the file size or colour depth has something to do with it. Perhaps we're limited to a 1Kb picture? I'll try and find out in the morning. |
Cheers Tom, thank god I'm not alone with this one.
I re-donwloaded the file and tried again but still no good
Let me know if you have any luck, I think you may be on to something with the bitmap properties as the icon for the temp cams seems to work ok and seem to be same as the previous GATSO bmp from the previous cam database.
Its a little dissapointing if the Navman has such a basic limit for the poi bmp's, come to think of it most of the poi bmp's are pretty basic.
Richard (EFC) |
Posted: Wed Dec 01, 2004 11:08 am Post subject: |
EFC
If you send me a Private Message with your email address in it then I will email you the bitmaps. Tim has tested them for me The new ones use 16 colour bitmaps (no difference in appearance).
Richard |
