Pocket GPS World :: View topic - UK speed & Redlight POI's.. for D3 get them HERE
CdRsKuLL
PostPosted: Tue Oct 26, 2004 11:46 am    Post subject: UK speed & Redlight POI's.. for D3 get them HERE Reply with quote
ok, after alot of playing about these should work on the D3 PocketPC
Download them at http://www.x-digital.addr.com/D3POI.zip
make sure you read the 'how to install' doc
I think its only fair after I downloaded the POI's from here that I should post the results..
Any prob's mail me.
cheers
Steve
davidjames
PostPosted: Mon Nov 01, 2004 3:59 pm    Post subject: Reply with quote
Managed to get it to show the speed camera icons which is great but no sound and no red light icons or sounds. Has anyone else had any luck with it?
davidjames
PostPosted: Wed Nov 24, 2004 8:10 pm    Post subject: Reply with quote
Am I the only person who's downloaded this? Anyone had any joy?
jellied
PostPosted: Thu Nov 25, 2004 1:08 pm    Post subject: Reply with quote
I think we need to upgrade to version 3.0.75 in order to allow imports of POIs - and likewise that version has a feature that alerts you nearby selected POIs - which I case is ideal for this sort of thing.
cheng
PostPosted: Tue Nov 30, 2004 8:46 pm    Post subject: Reply with quote
Have followed installation and all went well, but trying to use it, when you go to Favorites Destinator just freezez, needs warm start to get going
any hints?
cheng
PostPosted: Tue Nov 30, 2004 9:18 pm    Post subject: Reply with quote
Embarassed ok so stop pressing buttons and let the machine do it's own thing. Ta Da it works.
So how did you do it? and will you be keeping it up to date?
Good work that man Laughing
GPSinC3
PostPosted: Thu Dec 09, 2004 8:55 pm    Post subject: Reply with quote
I think its not a good idea to try and list all the speed cameras, may eventually do it, but I gave up and rebooted, think you should just select the alert favourites.
Haven't been out with it yet, was waiting to load 3.075 and new maps (see other thread)
D3 slow to load up first time, presumably a lot of cameras !
Does the alert work and is it timely ? Will we be able to get updates periodically ?
GPSinC3
PostPosted: Fri Dec 10, 2004 11:49 pm    Post subject: Reply with quote
It works, a noise happens when near a speed camera, and I have now found how to set alerts, I have opted for 400 yds single alert but you can change from 50 to 1000 and also have two stage alerts.
Seems quite accurate ie alram and yellow boxs by roadside match
jellied
PostPosted: Sun Dec 12, 2004 7:33 pm    Post subject: Reply with quote
Is it only slow to load the very first time you run D3 after importing the cameras, or everytime you run D3? It's quite slow already on my 5450.
GPSinC3
PostPosted: Sun Dec 12, 2004 9:57 pm    Post subject: Reply with quote
It was very slow first time, but is I think slower than before each time but not as slow as first time...I think that makes sense
cheng
PostPosted: Mon Dec 13, 2004 8:58 pm    Post subject: Reply with quote
was slow first time out but then seems to get it's act together. mind keep crashing the acer n30 anyway but thats another story
GPSinC3
PostPosted: Tue Dec 14, 2004 12:10 am    Post subject: Reply with quote
Interesting, I also seem to be having more lock ups and failure to load since upgrading and loading speed cameras, as I did both, its difficult to tell which if any is to blame. It used to be very bad when I had a Loox, with IPAQ 2210 very stable on 3.065, now somewhat worse, I might try unloading cameras and see if it makes a difference, also seem to have low battery problems, even switched off it flattens overnight, maybe something is still ticking away in the background, any suggestions welcomed
GPSinC3
PostPosted: Tue Dec 21, 2004 8:01 pm    Post subject: Reply with quote
Taken off cameras, reinstaled D3, seems to solve most of problems, still sometimes locks uop, but trick seems to be always shut D3 down and switch off, trying to get it back after suspend leads to more lock ups at splash screen, never mind other bits worth the upgrade
fordten7w
PostPosted: Mon Dec 27, 2004 9:48 am    Post subject: Reply with quote
Worked first time on Acer N30 but the noise and alerts happen when you are just about on top of camera Is it possible you could let us know how to change the alert settings
GPSinC3
PostPosted: Sat Jan 08, 2005 8:33 pm    Post subject: Reply with quote
There are settings in auto alert which allow you to change from memory, I've still not put mine back, they allow 100 yards or metres intervals
