Pocket GPS World :: View topic - How does GR-231 mouse mode work?
wibbly
PostPosted: Fri Nov 26, 2004 8:53 pm    Post subject: How does GR-231 mouse mode work? Reply with quote
The GR-231 had a mode that switches the receiver off when there's no Bluetooth link for more than 15min. So if I'm using it without Bluetooth, how does it "know" to stay on?
The manual shows the serial interface having both transmit and receive lines. Does the communicating software have to keep sending the 231 something to keep it awake? I thought NEMA protocol was only one way, from the receiver?
John
PostPosted: Sat Nov 27, 2004 9:51 am    Post subject: Reply with quote
The other end (PC or Pocket PC) can send configuration commands back to the receiver. For example which NMEA sequences to send at which interval, switch between NMEA and SiRF mode, trickle mode parameters, SBAS, reset of current GPS position etc etc. That's why the receiver needs both lines.
wibbly
PostPosted: Sat Nov 27, 2004 1:44 pm    Post subject: Reply with quote
So if the PC/PPC application doesn't send it anything (it's just looking for NMEA data), then without a Bluetooth connection, the 231 will just go to sleep after 10mins? :-(
J
Mapwalker
PostPosted: Sun Nov 28, 2004 3:24 pm    Post subject: Reply with quote
After posting a new thread about this I discovered I should have placed it overhere.
It seems Holux made a huge mistake that makes their mouse-mode useless!
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=13735
wibbly
PostPosted: Tue Nov 30, 2004 8:46 am    Post subject: Reply with quote
Hmm, th ereview here mentions lower power mode too. Presumably this wasn't verified.
J
wibbly
PostPosted: Tue Nov 30, 2004 8:48 am    Post subject: Reply with quote
Oops. Message above in wrong thread. What I meant to say was that the mouse mode was mentioned in the review here (as well), but presumably the issue of the unit shutting down either wasn't teted or wasn't experienced at all.
J
22.064 (26 Jun 24)
