pjn Occasional Visitor
Joined: Mar 03, 2004 Posts: 34 Location: Perth, Western Australia
Posted: Mon Nov 22, 2004 11:25 pm Post subject: Quick simple software to allow soft reset from today screen? |
To cut a long story short, TT3 continually hangs on my HP4150 (from earlier discussions this seems to be down to my Sandisk SD card). The only way I can get Bluetooth connection again is to soft reset the unit, which is a little hazardous when driving!
So I'm looking for something that will add a good-size 'Reset' icon to the Today screen - has anyone come across any free utility to do this?
Thanks!
Pete |
Talkingbollox Frequent Visitor
![](modules/Forums/images/avatars/1669536683418e9e94aaf72.gif)
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
Posted: Tue Nov 23, 2004 9:22 am Post subject: |
Thanks - that should do the job!
Better than removing the device from the cradle and trying to find the reset hole when it's dark :D |
DavidW Pocket GPS Moderator
Posted: Tue Nov 23, 2004 1:04 pm Post subject: |
Spb's Pocket Plus, if you turn on the feature that allows you to make X close rather than minimise programs, can bring up a menu if you tap and hold on the X. You can add Soft Reset to that menu, which is the shortcut I use if I need to soft reset without uncradling my setup.
David |
nej Frequent Visitor
Joined: Jun 16, 2004 Posts: 454 Location: London, Ingerlund
Posted: Tue Nov 23, 2004 1:55 pm Post subject: |
I did a little eVB program that will reset the PocketPC. I assign it to a hardware button on the front, so a reset is just a button-press away.
If anyone wants it I'll happily post it somewhere (it needs the eVB runtimes though). |
Posted: Wed Nov 24, 2004 8:26 pm Post subject: |
Looks very simple - and the price is right too!
I'm glad you found something to meet your needs.
David |
