Pocket GPS World :: View topic - Quick simple software to allow soft reset from today screen?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
pjn
PostPosted: Mon Nov 22, 2004 11:25 pm    Post subject: Quick simple software to allow soft reset from today screen? Reply with quote
To cut a long story short, TT3 continually hangs on my HP4150 (from earlier discussions this seems to be down to my Sandisk SD card). The only way I can get Bluetooth connection again is to soft reset the unit, which is a little hazardous when driving!
So I'm looking for something that will add a good-size 'Reset' icon to the Today screen - has anyone come across any free utility to do this?
Thanks!
Pete
Talkingbollox
PostPosted: Tue Nov 23, 2004 12:32 am    Post subject: Reply with quote
Try http://www.pocketgear.com/software_detail.asp?id=6666
Not quite on the Today Screen, but accessible via Start/Programs.
pjn
PostPosted: Tue Nov 23, 2004 9:22 am    Post subject: Reply with quote
Thanks - that should do the job!
Better than removing the device from the cradle and trying to find the reset hole when it's dark :D
DavidW
PostPosted: Tue Nov 23, 2004 1:04 pm    Post subject: Reply with quote
Spb's Pocket Plus, if you turn on the feature that allows you to make X close rather than minimise programs, can bring up a menu if you tap and hold on the X. You can add Soft Reset to that menu, which is the shortcut I use if I need to soft reset without uncradling my setup.
nej
PostPosted: Tue Nov 23, 2004 1:55 pm    Post subject: Reply with quote
I did a little eVB program that will reset the PocketPC. I assign it to a hardware button on the front, so a reset is just a button-press away.
If anyone wants it I'll happily post it somewhere (it needs the eVB runtimes though).
pjn
PostPosted: Wed Nov 24, 2004 7:15 pm    Post subject: Reply with quote
Thanks for the suggestions - I decided to use this one and assign it to a hardware button:
http://www.pocketgear.com/software_detail.asp?id=14504
DavidW
PostPosted: Wed Nov 24, 2004 8:26 pm    Post subject: Reply with quote
Looks very simple - and the price is right too!
I'm glad you found something to meet your needs.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.062 (12 Jun 24)
