Pocket GPS World :: View topic - Questions over the new MN4 GPS unit...
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds
swing
PostPosted: Sun Nov 21, 2004 11:13 pm    Post subject: Questions over the new MN4 GPS unit... Reply with quote
How does this GPS unit work? Does it have a rechargable battery? Basically, I'm wondering whether it's possible to leave it hidden from site (with maybe just a GPS external antenna) on show (say in the glovebox) to save having to turn it on and off, like I have to with my current GPS.
PostPosted: Mon Nov 22, 2004 9:48 am    Post subject: Reply with quote
The GPS needs to be permanently powered from the accessory power socket just like all other GPS Mouse Receivers. The same goes even when you have the Bluetooth module connected. in theory you could leave it physically switched on all the time providing you can hardwire the power so it doesn't go off when you turn the ignition off.
swing
PostPosted: Mon Nov 22, 2004 3:29 pm    Post subject: Reply with quote
Dave wrote:
In theory you could leave it physically switched on all the time providing you can hardwire the power so it doesn't go off when you turn the ignition off.
What's the problem with simply having the GPS powered via a switched ignition socket?? Obviously after a while the GPS will run out of battery and turn itself off, but I believe the GPS has a physical On/Off slider, so once power is restored won't the GPS simply turn back on without further user involvement?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navigon Handhelds All times are GMT + 1 Hour
