kblackburn Occasional Visitor
Posted: Sat Nov 20, 2004 10:50 pm Post subject: urgent help required |
This just gets worse, i earlier downloaded checkpoint3.2, but couldn't get it to run, so sought advise from this forum, removed it as suggested and installed version2.0, this will not run either, i now have two icons in my programs folder and clicking on either dont get any response, what's going on !!!. should it be stored on the sd card or somewhere else, i seriously need assistance with this, step by step if any one can help.
kevin |
alix776 Pocket GPS Moderator
Posted: Sat Nov 20, 2004 11:08 pm Post subject: |
it should be stored on the ppc as it intergrates with tomtom if you could give us more info on the problem maybe we could help of have a look through the checkpoint forum first _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
DavidW Pocket GPS Moderator
Posted: Sun Nov 21, 2004 3:20 pm Post subject: |
If you have left over icons from programs you've uninstalled, you can browse into \Windows\Start Menu, find and delete the respective link (which may be in a sub folder).
You can either use a program on the Pocket PC to do it (the built in File Manager, or something like Resco Explorer 2003), or you can use ActiveSync's Explore feature. Start out selecting "My Pocket PC", then Windows and Start Menu.
David |
Posted: Sun Nov 21, 2004 7:17 pm Post subject: |
Hi David,
ok, gone into active sync/ explorer/my ppc/
windows& start menu. deleted the checkpoint version3 icon. great.
But on the ppc, the ion for checkpoint 2.0, when you touch the icon with the stylus it gives the impression that it's giong to work, but nowt happens.
whats next. do i uninstall this and buy GPSAssist or what, or is it me being totally thick ![Embarassed](modules/Forums/images/smiles/icon_redface.gif) |
Posted: Sun Nov 21, 2004 9:08 pm Post subject: |
Are you sure there's not a little blue icon down at the bottom right of your Today screen when you run CheckPOInt? If there is, tap it (it may be a tap and hold) and the CheckPOInt menu should appear so that you can set it up.
David |
Posted: Sun Nov 21, 2004 9:30 pm Post subject: |
Hi David,
right, i've got the little icon, bottom right of today screen, i've set the general and international settings, but when i go to navigator properties, can find OTHER PROPRETIES as listed in the checkpoint instructions, scroll down, no pocketgps-uk or anything else to do with speed cameras.
an you help again, i downloaded pgsspeed cameras from this site, so it must be somthing i'm doing wrong.
kevin |
Posted: Sun Nov 21, 2004 9:41 pm Post subject: |
Assuming that you've unpacked the file you've got and put the .ov2 and .bmp files in the appropriate map folder, you should be able to select the POIs in TomTom Navigator. If not, you need to solve that problem before going any further with CheckPOInt.
If you have the POI files available in TomTom Navigator, it's then a case of activating the warnings you want in the Overlay Settings screen of CheckPOInt. Most people choose to tell CheckPOInt to start Navigator when CheckPOInt is started, and shut down when Navigator is shut down. That way, you just select CheckPOInt to start navigating.
If you do this, you can get back to the settings by starting CheckPOInt, switching back to the Today screen, and accessing the CheckPOInt icon that way.
David |
Posted: Sun Nov 21, 2004 9:44 pm Post subject: |
David,
do i have to copy each file over indivually,
kevin |
Posted: Sun Nov 21, 2004 9:54 pm Post subject: |
It depends what you're trying to do. If you're trying to install from the Zip file, yes - make sure you put the files into your map folder.
It may be easier to set up POIedit to use the POIsync service with Pocket GPS World. You only have to sort it out once - you can then use the features to keep your POI files up to date when they're re-released periodically. Do make sure you have an active ActiveSync connection to your Pocket PC when you start POIedit.
David |
Posted: Sun Nov 21, 2004 10:05 pm Post subject: |
David,
right, done it , i copied all files seperetly and now there where they should be. Thanks very much for your help, i'm off out to try now.
any problems and i'll be back.
kevin |
Posted: Mon Nov 22, 2004 3:47 pm Post subject: |
Well done! It's a bit of a steep learning curve, but you have hopefully come out from it having learnt rather more about Pocket PCs and handling files.
David |
