Pocket GPS World :: View topic - Medion
Medion
martinmsc19671
PostPosted: Tue Nov 16, 2004 5:46 pm    Post subject: Medion Reply with quote
Please can some one tell me what I need to to to get the speed camera program on the Medion Navigator. I am a bit confused do I need the upgrade or what? Question
Pocketgps
PostPosted: Tue Nov 16, 2004 8:54 pm    Post subject: Reply with quote
If this is the New Aldi 95000 (Mio168) then you need to follow these instructions.
1. http://www.navigating.de/Medion4_en/POI/Index.htm
Follow all the instructions to install and register the POI-Warner utility.
2. Download the file : http://www.pocketgpspoi.com/downloads/pocketgps_uk_sc.zip
3. Download and install this program : http://dnote.demon.nl/public/PoiEdit_v32.exe
4. Run the PoiEdit_v32.exe to install.
5. Un-zip the pocketgps_uk_sc.zip to the the PoiEdit folder
6. Start PoiEdit, click on the Tools - Batch Convert, you should see the files you un-zipped from pocketgps_uk_sc.zip, just click Convert, within a second the files will be converted, then just close PoiEdit, browse to its folder and you will find the converted files with the .asc ending. Copy the files:
pocketgps_uk_gatso.asc
pocketgps_uk_mobile.asc
pocketgps_uk_redlight.asc
pocketgps_uk_specs.asc
6. Put your Pocket PC in its cradle and start ActiveSync, (if not already started), then browse to the folder
\Program Files\POIWarner MN4-Edition\pois
then Paste the files you copied above into this folder.
7. You will also need to copy the 4 image files from the PoiEdit folder:
then Paste them to the same folder as above.
8. Then click Start on your Pocket PC - Programs - then start POI-Warner
and configer each of the tabs, this takes a bit of learning so is much to long to post here, but its not that hard.
Go out and try it, should work.
Hope this helps.
Pocketgps
en1gma
PostPosted: Thu Nov 18, 2004 7:43 pm    Post subject: Reply with quote
The POIEdit.exe download site appears to be down - anyone have anynore info/other options?
DavidW
PostPosted: Thu Nov 18, 2004 8:01 pm    Post subject: Reply with quote
The second download link for 3.2 (the one not marked recommended) here works.
23.021 (05 Feb 25)
