dice Occasional Visitor
Posted: Thu Nov 11, 2004 10:10 pm Post subject: Medion and poi's |
Well I have just bought the Aldi Medion(Mitac163?) for £250 Can I get poi software for it as I had with TT3? I would like to put the speed camera database on my ppc. |
Jono Occasional Visitor
Joined: Nov 11, 2004 Posts: 19 Location: North Yorkshire
Posted: Sat Nov 13, 2004 1:01 pm Post subject: |
Yes you can, I got this one:
http://www.navigating.de/Medion4_en/POI/Index.htm
I used the speed camera o2v files from this site (converted to asc with POI edit) then just uploaded them to the PDA. Works great  |
Posted: Sat Nov 13, 2004 1:30 pm Post subject: |
Thanks Jono working fine now  |
JaceyBoy Occasional Visitor
Posted: Mon Nov 15, 2004 4:31 pm Post subject: |
I have this to and am struggling to get the POI working, can someone tell me how to convert the UK Speeding files?
Thanks  |
Posted: Mon Nov 15, 2004 4:33 pm Post subject: |
Ugent, thanks  |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Mon Nov 15, 2004 4:58 pm Post subject: |
Hi JaceyBoy,
to the forum.
Jono wrote: | I used the speed camera o2v files from this site (converted to asc with POI edit) then just uploaded them to the PDA. Works great  |
I don't have the software but try Jono's suggestion. I use WinOV2 to convert .OV2 files to .ASC format.
Garmin Camper 770 LMT-D |
Posted: Mon Nov 15, 2004 7:30 pm Post subject: |
Privateer wrote: | Hi JaceyBoy,
to the forum.
Regards, |
Thats the way it works fine :D |
en1gma Occasional Visitor
Posted: Tue Nov 16, 2004 7:29 pm Post subject: |
Hi, I'm new to this, too ; so to check, this is what I have to do:
*Buy/download the Warner POI sw and activate it
*download the Speed Camera data from this forum/site
*convert the file format of the latter data to .asc
*transfer this data to the PDA
*Bob's my uncle...
OK, where do I find the POI edit/WinOV2 Convert software?
In exactly which folder do I transfer the data to, on my PDA? |
Posted: Tue Nov 16, 2004 8:15 pm Post subject: |
en1gma wrote: | Hi, I'm new to this, too ; so to check, this is what I have to do:
*Bob's my uncle...
Cant remember where I got the software but I did Google it"convert OV2 to ASC" Then tranfer the files to the Warner POI folder on your pda  |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Nov 16, 2004 8:34 pm Post subject: |
1. http://www.navigating.de/Medion4_en/POI/Index.htm
Follow all the instructions to install and register the POI-Warner utility.
2. Yes - http://www.pocketgpspoi.com/downloads/pocketgps_uk_sc.zip
3. http://dnote.demon.nl/public/PoiEdit_v32.exe
4. Run the PoiEdit_v32.exe
5. Un-zip the pocketgps_uk_sc.zip to the the PoiEdit folder
6. Start PoiEdit, click on the Tools - Batch Convert, you should see the files you un-zipped from pocketgps_uk_sc.zip, just click Convert, within a second the files will be converted, then just close PoiEdit, browse to its folder and you will find the converted files with the .asc ending. Copy the files:
pocketgps_uk_gatso.asc
pocketgps_uk_mobile.asc
pocketgps_uk_redlight.asc
pocketgps_uk_specs.asc
6. Put your Pocket PC in its cradle and start ActiveSync, (if not already started), then browse to the folder
\Program Files\POIWarner MN4-Edition\pois
then Paste the files you copied above into this folder.
7. You will also need to copy the 4 image files from the PoiEdit folder:
then Paste them to the same folder as above.
8. Then click Start on your Pocket PC - Programs - then start POI-Warner
and configer each of the tabs, this takes a bit of learning so is much to long to post here, but its not that hard.
Hope this helps.
Pocketgps |
marcusfox Occasional Visitor
Posted: Wed Nov 24, 2004 1:38 am Post subject: |
Very helpful thanks.
Can I use the POI-Warner from this site (says for TT) with the Medion software or is it only for TT?
Marcus |
Posted: Wed Nov 24, 2004 9:47 am Post subject: |
marcusfox wrote: | Very helpful thanks.
Marcus |
There is a version for the medion only use that one not the one for TT  |
Posted: Wed Nov 24, 2004 1:50 pm Post subject: |
dice wrote: | marcusfox wrote: | Very helpful thanks.
Marcus |
Is there a free version available or is it the pay version mentioned earlier in this thread?
Marcus |
Posted: Wed Nov 24, 2004 3:54 pm Post subject: |
marcusfox wrote: | dice wrote: | marcusfox wrote: | Very helpful thanks.
Marcus |
Marcus |
It's not free it cost about £18 I think. but it is good! |
Scampa Occasional Visitor
