Pocket GPS World :: View topic - how much memory
how much memory
bertybasset
PostPosted: Sun Nov 14, 2004 6:02 pm    Post subject: how much memory Reply with quote
can somebody please tell me how much of a memory card i need to put in so that i can have all the camera points listed as i tried to add the speed cameras as poi with a 256mb card and it said not enough room -- would a 512 be sufficient for this task ?
PostPosted: Sun Nov 14, 2004 7:37 pm    Post subject: Reply with quote
I get all the camera databases on - all four, on the standard card.
Den
Simon1
PostPosted: Sun Nov 14, 2004 10:08 pm    Post subject: Reply with quote
If you haven't already done so, I suggest you have a look at http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=13041
bertybasset
PostPosted: Sun Nov 14, 2004 11:21 pm    Post subject: Reply with quote
Den
when you said you got all four on a standard card -- the card i got pre loaded with maps is full so i copied the maps from cd to a 256mb card and tried to load databases on to it but it said there was not enough space on card so how did you get them all on yours -- what size of card have you got ? also when i go into setting - maps - iternal memory it says there are no maps loaded -- is this correct or have i not loaded maps that i should have?
PostPosted: Mon Nov 15, 2004 12:20 am    Post subject: Reply with quote
I just installed the camera databases onto the 128 meg that came with the unit. It worked fine. Maps don't load onto internal memory - they are on the card. I think maps only load into internal memory on the hard disk based navmans which this is not - probably standard software that covers both types of machine. I just follwed the directions given above on the link to load the files.
Den
bertybasset
PostPosted: Mon Nov 15, 2004 7:04 pm    Post subject: Reply with quote
Den
many thanks dennis i have done what you said and it appears to have loaded fine this time --many thanks for your help dennis
