Pocket GPS World :: View topic - Problems running POI-Sync ?
PostPosted: Fri Mar 12, 2004 11:38 pm    Post subject: Problems running POI-Sync ? Reply with quote
Having problems getting POI-Sync to work ? A common problem is because you have Internet Explorer configured to use a proxy server. If you aren't using a proxy server or don't know one is and you are on a dial-up, adsl or cable configuration, following this link and it will get you up and running in minutes.
CS
PostPosted: Sun Mar 14, 2004 11:13 pm    Post subject: Reply with quote
Thanks Dave for this reminder which worked a treat. The Automaticallt Detect Settings in IE was ticked and that was preventing Autoupdate now from working. What a clever person you are! Thanks.
CS
PostPosted: Sun Mar 21, 2004 3:58 am    Post subject: POI Edit V 3.0: Auto update problems Reply with quote
Dave - You may recall that I had to do a hard reset on my iPaq 3800. It's now working again but I can't get POI Edit v3 to auto update as it did before the hard reset. I have followed your link instructions and everything is set as it should be but I keep getting the following message:
Can't resolve host name to IP address. Pl check internet connection & IE Proxy settings (optionally you can set proxy settings manually from Online/Proxy Settings menu).
Also I can't seem to find any ov2 files in the map file in my storage card even though I don't get an error message when I save as a ov2 file on my PC.
Where am I going wrong?
PostPosted: Sun Mar 21, 2004 8:14 am    Post subject: Reply with quote
Read the front news page Idea
We're moving one of the servers to a new datacentre and this is currently still down. This will cause problems with download POI's, using POI-Sync and grabbing downloads from the site.
We'll post as soon as we know it's back up and running.
Aquanick
PostPosted: Sat Nov 13, 2004 5:56 pm    Post subject: Reply with quote
Followed the link above....
No information on proxy servers just some question about entering a password.
I have followed all instructions......and it still fails to work.
Iam sure its to do with the proxy settings....
Need help!
Nick
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sat Nov 13, 2004 8:55 pm    Post subject: Reply with quote
It's because you have screwed around with your IE settings, follow this link.
Aquanick
PostPosted: Sun Nov 14, 2004 9:32 pm    Post subject: Reply with quote
Tried as you sugested........now get the following errors....
Please install MSXML2 or higher (have allready downloaded and installed this)
Access violation at address 0051F9CE in module POIEDIT.EXE, read of address FFFFFFFFFF.
I am connecting with AOL......is this the problem....coz I have had problems with AOL and other software in the past.
Nick
PostPosted: Mon Nov 15, 2004 7:07 pm    Post subject: Reply with quote
No, XML2 is required and only present in WinXP onwards.
Check out http://www.dnote.nl/ and read the IMPORTANT section, once you have installed XML2 support you should be good to go (providing you leave the proxy info off of IE).
Aquanick
PostPosted: Mon Nov 15, 2004 8:56 pm    Post subject: Reply with quote
Have followed all you sugested.
Have allready installed the latest version of XML......version 4 is the one which comes off the website.....I think I installed it correctly, got messages back saying the intalation was succesfull.
But still POIedit fails to function.
Wot I really need is to be able to have a map of great britain on the screen, only get a map of benelux.
Tryed autoupdate and still get the same error messages as detailed above.....
HELP ME PLEASE! coz its seriously doing my nut in now Evil or Very Mad
Nick
PostPosted: Tue Nov 16, 2004 2:16 pm    Post subject: Reply with quote
Well the error message is due to XML issue. If you are still having problems, I suggest you try and email the author Dave over at Dnote.nl
Sush
PostPosted: Wed Jan 12, 2005 5:49 pm    Post subject: Reply with quote
I downloaded the software from this website & followed the instructions.
I need some help with downlaoding updated speedcams on copilot 5. When I unzipped the downloaded file (pocketgps_uk_sc) I got a number of excel files. (gatso, specs, temp,redlight, continental).
I downloaded the gatso file as per the instructions. Do I need to download all the excel files to give me coverage of the cameras & if so how do I do it (the instructions were for only 1 file)
Sorry if I am making a very elementary mistake (I have only had my system for a week now!)
Sush
PS I had posted this query on the beginners forum but have had no response!
FG
PostPosted: Sun Mar 27, 2005 8:52 am    Post subject: Reply with quote
Dave,
I am having problems. Have done the proxy server stuff but now get an error message:
Connection refused (Error #10061) while recieving http file time.
Then the same request to check IE proxy settings
FG
PostPosted: Sun Mar 27, 2005 9:00 am    Post subject: Reply with quote
OK, have just seen a relevant thread, POI EDIT connection please help going round the bend, will keep an eye on that.
brooke123
PostPosted: Tue Mar 29, 2005 9:00 am    Post subject: Reply with quote
same problems with update in poiedit, getting proxy problems, previously had no problems at all!!, ( I bet youre sick of these proxy problems).
The Dutch website say's there is a problem at your end, I see you've changed servers recently.
Followed the link re settings to the letter, still won't work, even re installed programme twice. Do you thinK it best to wait and see? Confused
brooke123
CS
PostPosted: Tue Mar 29, 2005 1:03 pm    Post subject: POI Edit updates Reply with quote
I seem to be having problems updates again. I've just changed over to POI Edit v 3.5.5. and checked the IE settings again as the link below and all is OK. Is there a problem with the server or is this there something wrong at my end?
22.094 (25 Sep 24)
