Pocket GPS World :: View topic - Newbie needs advice please
rcflyers
PostPosted: Thu Nov 11, 2004 8:16 pm    Post subject: Newbie needs advice please Reply with quote
Hi, I have just bought one of those Aldi Medion 95000 Pda/Gps devices.
What software do I need to install in order to warn me of speed cameras?
Perhaps there is already within this website a guide I can follow,
Thanks for any help.
rcflyers
PostPosted: Thu Nov 11, 2004 10:45 pm    Post subject: Reply with quote
Update!
I managed to install POI Warner 2.32, downloaded the speed camera file from this site, converted the ov2 files to asc using the Tom Tom POI editor and uploaded them to the PDA.
I also uploaded the 5 excel worksheet and the 5 excel csv files into the PDA's POI folder (not sure if this was required)
I went out for a drive past a known speed camera, but it gave me no visual or audible warning at all, The only difference I have noticed is I have a red to green coloured bar at the bottom of the screen (that does nothing.)
Please tell me where I have gone wrong,
Jono
PostPosted: Fri Nov 12, 2004 11:28 am    Post subject: Reply with quote
From the website:
POI-Warner version 2.3 (unregistered)
System requirements:
Medion-Navigator for PDA (all versions below 4)
Attention: Medion-Navigator 4 is not supported yet!
Could this be why? My PPC has version 4.2 of the Navigator software on it. I'm assuming yours has too. Sad
Has anyone successfully got the POI-Warner software working properly with the new Aldi unit? I would love to have it, but if it's not going to work then there seems little point Sad
Jono
PostPosted: Fri Nov 12, 2004 11:30 am    Post subject: Reply with quote
Ah ignore that - shame you can't edit posts Embarassed
It seems there's an upgrade for Medion Navigator 4 available....do you have that (if it's required)
Jono
PostPosted: Fri Nov 12, 2004 12:25 pm    Post subject: Reply with quote
I'm new to this too, but because I'm so nice, I just downloaded and registered this software myself, and added the speed cam stuff. Hooray.
By default, there didn't seem to be any audible warnings set.
If you go to POI-Manager menu >> POI-Settings >> Acoustic alert
You have to add the POIs to the warnings with the +/- button, which should present you with a list of possibilities. Add the ones you want, then go to first/last warning tabs and select standard warning (or another if you prefer it)
I've not tested this yet, as i don't really live near any speed cameras....but you should be able to test it and tell me if it works :D
rcflyers
PostPosted: Fri Nov 12, 2004 2:18 pm    Post subject: Reply with quote
hi there,
i have deleted nav 4 and installed tom tom 3 instead as it seems to be a more popular product, i will install poi warner and camera database tonight and let you know how i get on.
IanHunt
PostPosted: Fri Nov 12, 2004 3:51 pm    Post subject: Reply with quote
I also bought one of these Aldi pdas yesterday.
This morning I installed & registered Poi-Warner, ie the program that monitors where you are on the map and whats coming up(i.e. speedcameras).
Step 2 - I downloaded the speedcam database from this site and unzipped it to my PC. N.B.The files were in tomtom format (*ov2) so needed converting as in Step3 below..
Step 3 - Downloaded Poi-Edit from this site and installed it to my PC. Opened poiedit and converted the .ov2 files to .asc file format (Tools/batch convert).
Step 4 - Copied the *.asc files from my PC to the POIWarnerMN4-Edition/pois folder on the PDA and the .bmp file to give the speed camera icon on the map.
Step 5 - Found the cameras listed in the POI-Manager, POI-Settings, Overlaysettings list in POI-Warner.
Step 6 - about with .wav files to use for audible warnings.
I've been out in the car this afternoon and it works a treat. Dead chuffed as setting it up was dead easy when I thought it was going to be a bit tricky. Smile
Hope this helps.
Ian
rcflyers
PostPosted: Fri Nov 12, 2004 7:43 pm    Post subject: Reply with quote
I installed tomtom3, checkpoint then camera database, bit of fiddling, seems to be working fine now, HOORAY!
Sniffer
PostPosted: Fri Nov 12, 2004 10:55 pm    Post subject: Reply with quote
How easy was it to can the Navigon s/w and install tomtom3 ? I'm considering doing that so I can d/l the utility that allows full 7-digit postcode searches.....
Would it be straightforward to re-install Navigon if I didn't like tomtom ?
rcflyers
PostPosted: Fri Nov 12, 2004 10:58 pm    Post subject: Reply with quote
i backed up the memory card to my pc, then deleted all files on it, installing tt3 was easy, not sure about reinstall tho, good luck!
Sniffer
PostPosted: Fri Nov 12, 2004 11:03 pm    Post subject: Reply with quote
I guess I probably wouldn't go back to Navigon anyway. I'll give it a whirl over the weekend - fingers crossed !!
