Pocket GPS World :: View topic - POI Only Visible When Stationary
spacerace
PostPosted: Thu Nov 11, 2004 10:26 pm    Post subject: POI Only Visible When Stationary Reply with quote
Not sure if anyone else has experienced this, I've been searching but found nothing.
I installed CoPilot from the quickstart Mini-SD card and all worked fine. I then decided to add in the Speed Camera database to the inbuilt POI list.
I followed the instructions for importing and then downloaded all the data to the Mini-SD card afresh and re-installed.
Now the problem is that all POI (existing and new speed cameras) are only visible when stationary. When I am moving they all disappear ! I can temporarily fix this by switching views which shows all the POIs on the new view up until the point where I come to a stop. As soon as I move again they all disappear again.
Anyone any idea what might be causing this ? I have all POI settings switched on in Options, and have uninstalled and re-installed twice now.
I can't remember if it ever worked ok but I guess it must be something I broke upon updating the installation.
- spacerace -
Skippy
PostPosted: Thu Nov 11, 2004 11:46 pm    Post subject: Reply with quote
Welcome! :D
This has been noticed before and apparently the POI disappearing is a "feature" of CoPilot. Personally, I think it is a negative feature. Confused :x
Gone fishing!
spacerace
PostPosted: Fri Nov 12, 2004 12:05 am    Post subject: Reply with quote
thanks for the reply.
a feature, really ? I'd been through several reviews and every screenshot showed a moving icon with various POIs visible. I assumed they were normally there and that I had some sort of problem. I must have also missed where this 'feature' was mentioned in the manual !
Sorry for not checking more carefully and thanks for clearing it up for me.
- spacerace -
PostPosted: Fri Nov 12, 2004 10:02 am    Post subject: Reply with quote
I don't know the exact reason why POI's are only viewable when stationary, but I'll drop a suggestion in here. TomTom Mobile has been having huge problems displaying over 1000 POI's on a map, I believe this is due to the low (or lack of) memory available on the SmartPhones, so it's quite possible that this has been disabled to stop a dramatic slow down in CoPilot.
stuartm
PostPosted: Fri Nov 12, 2004 10:22 am    Post subject: Reply with quote
They will have difficulty showing large numbers of POIs but it shouldn't be a problem to display the few that will be visible at the sort of zoom levels you get whilst driving. On one of the few times I've actually had a response from ALK they said that the disappearing POIs was designed that way to avoid distracting the driver.
spacerace
PostPosted: Fri Nov 12, 2004 11:13 am    Post subject: Reply with quote
you see I don't find them a distraction at all. In fact it's easier to check your real progress matches the indicated progress by seeing if you do in fact have a petrol station on your right, than a road junction etc.
also if you're driving down the motorway a visual indication of a hotel or petrol station approaching simply isn't going to happen ! I suppose you have the notifications but few people have them switched on for every category.
- spacerace -
spacerace
PostPosted: Fri Nov 12, 2004 11:15 am    Post subject: Reply with quote
but if I switch views (say to 3d map) it shows all the POIs quite happily until I halt and resume again, at which point they promptly disappear ! doesn't seem to produce any memory errors / problems.
also I understand the safety argument, but it really should be a switchable menu option.
- spacerace -
22.063 (19 Jun 24)
