Pocket GPS World :: View topic - TT3 3.07 Update
TT3 3.07 Update
st1967
PostPosted: Sat Nov 06, 2004 5:26 pm    Post subject: TT3 3.07 Update Reply with quote
I have done the 3.07 update on my Ipaq 3870 and am now a little worried I should not have done this.
I've seem all the other posts about it being mainly for the 6xxx series of Ipaq's and TomTom support advising people not to upgrade past 3.03 if you don't have one.
Does anybody know what might happen? My TT3 still works OK with the new update.
lbendlin
PostPosted: Sat Nov 06, 2004 5:47 pm    Post subject: Reply with quote
TTN 3.07 is supposed to make address lookup faster - something everybody can benefit from. As long as you don't install GPS 3.07 you are fine.
Lutz
TomTom/TeleAtlas NAVTEQ
SteveW
PostPosted: Sat Nov 06, 2004 6:16 pm    Post subject: Reply with quote
I have loaded both on my 2210 and it is working fine.
Steve
Wilko
PostPosted: Sat Nov 06, 2004 8:34 pm    Post subject: Reply with quote
Whats wrong with the GPS 3.07 driver?
I'm using it on my 2210 with no problems, since it was released.
lbendlin
PostPosted: Sat Nov 06, 2004 9:30 pm    Post subject: Reply with quote
TomTom GPS drivers tend to block the BlueTooth stack, and to prevent other programs from accessing BT receivers, even when TomTom is not running.
Lutz
Wilko
PostPosted: Sat Nov 06, 2004 9:53 pm    Post subject: Reply with quote
So the 2.x drivers are still being used?
I've been under the impression the lock was solved with one of the later 3.x releases. I'll the the version 2 driver another go :D
lbendlin
PostPosted: Sat Nov 06, 2004 10:37 pm    Post subject: Reply with quote
The lock is supposed to have been resolved with GPS 3.03 but we have heard mixed messages. Essentially you need to make sure that the original BT DLL is re-established, and the install/uninstall routines for TomTom GPS don't seem to always be successful at that.
Lutz
thor
PostPosted: Thu Nov 11, 2004 1:59 pm    Post subject: Reply with quote
Apologise in advance if this has been answered before, couldn't find the answer to my question below.
I downloaded the upgrade 3.07 and attempted to install it but on the last screen before it did the update it always shows both gps driver upgrade and the app upgrade. How can I upgrade only the app and not the gps driver.
If I understand the thread correctly, I will benifit from upgrading the application but not the GPS driver.
I'm running HP1940 with TT bluetooth gps and TT3 - UK.
Thanks,
Thor
lbendlin
PostPosted: Thu Nov 11, 2004 2:16 pm    Post subject: Reply with quote
On the TomTom support side they have separate downloads for the program and the GPS driver.
Lutz
Grant620
PostPosted: Sat Jan 22, 2005 9:52 pm    Post subject: Reply with quote
They do, but when you try and install just the program, it installs the GPS too!
Grant
View user's profile Send private message Visit poster's website MSN Messenger
lbendlin
PostPosted: Sat Jan 22, 2005 10:14 pm    Post subject: Reply with quote
Indeed - they seem to have changed that. Someone please hold me back or I use strong words...
If you want to be on the safe side, run the installer WITHOUT a Pocket PC attached, and then copy the Navigator CAB file to the Pocket PC and run it directly.
I also keep a copy of the CAB files on the storage card, just in case I feel the urge to reinstall everything.
Lutz
longitude
PostPosted: Wed Jan 26, 2005 5:18 pm    Post subject: Reply with quote
It's been a while since I checked this discussion board and realised I'm a bit behind as I'm still on version 3.01. However, from what I've read, I too am not sure if 3.07 is for me. I'm using an iPaq 3950, os version: Windows CE 3.0, Pocket PC v 3.0.11171. Can anyone advise?
lbendlin
PostPosted: Wed Jan 26, 2005 5:35 pm    Post subject: Reply with quote
I have been using 3.07 on that same machine without problems. One would assume that it has fixed some of the 3.01 bugs.
Lutz
MarkHewitt
PostPosted: Fri Jan 28, 2005 7:20 pm    Post subject: Reply with quote
I know 3.07 can stop some other GPS applications from running. But I have TomTom and nothing else installed on my ipaq. Are there any issues when other programs are not used? (I don't use bluetooth either)
lbendlin
PostPosted: Fri Jan 28, 2005 9:56 pm    Post subject: Reply with quote
No. This affects only BlueTooth.
Lutz
22.064 (26 Jun 24)
