Pocket GPS World :: View topic - Fortuna XT mode and TT3
Thrubwell
PostPosted: Fri Oct 29, 2004 3:45 pm    Post subject: Fortuna XT mode and TT3 Reply with quote
Can anyone tell me if TomTom have support for the XT mode of the clip-on?
I can use ST no problem but cannot talk using XT.
IPAQ 6365, Fortuna BT Clip-on, Parrot CK3000, TomTom 3 (with GPS driver 3.07)
tailazoom
PostPosted: Fri Oct 29, 2004 4:58 pm    Post subject: Reply with quote
tungsten t3 + tomtom 4.4 + clip-on xt mode = ok
Thrubwell
PostPosted: Fri Oct 29, 2004 6:05 pm    Post subject: Reply with quote
What settings do you have in TomTom GPS?, I have TomTom Navigator GPS and Bluetooth Serial port
tailazoom
PostPosted: Sun Oct 31, 2004 10:34 pm    Post subject: Reply with quote
Clipon is paired with tungsten t3 and in tomtom 4.4 i just select a generic (non tomtom) bluetotth gps: non need to configure anything.
Biggles_no1
PostPosted: Thu Nov 04, 2004 6:08 pm    Post subject: Reply with quote
I use an iPAQ 2210 and I have mine set to NMEA 0183v2 3840 and Bluetooth Serial Port.
It does work although (I am having big problems with accuracy usint xtrac at walking speed).
footman
PostPosted: Sun Nov 28, 2004 6:02 pm    Post subject: Reply with quote
Biggles...what software are you using for walking?
Laurence
Biggles_no1
PostPosted: Fri Dec 31, 2004 12:02 pm    Post subject: Reply with quote
Sorry for the delay. I am using tomtom Navigator 3
footman
PostPosted: Fri Dec 31, 2004 4:30 pm    Post subject: Reply with quote
Phew.... at last..I've been waiting by the PC for the reply!! :D
TT£ Navigator is not meant for walking, I use Memorymap.
Laurence
DavidW
PostPosted: Fri Dec 31, 2004 9:08 pm    Post subject: Reply with quote
As Laurence says, TomTom Navigator 3 isn't designed for walking, and it will keep trying to snap your position to the nearest road.
You need different software for walking. Topographic software such as Memory Map, Fugawi and Anquet is the best, but depending on the maps you want, may be pricey.
Biggles_no1
PostPosted: Wed Jan 19, 2005 6:13 pm    Post subject: Reply with quote
David/Laurence
Many thanks for the replies. As I was moslty aiming to use this in London I thought that snapping my position to the nearest road, (i.e. the road I'm walking along) would be a desired feature. Laughing Out Loud
Memory map looks interesting but also very expensive. It's just a shame I can't use the software I already have. Oh well I guess you can't have all things all the time.
I guess I'll have to look into some alternatives
Cheers guys,
Jason
thebatterystall
PostPosted: Sat Jan 29, 2005 1:03 am    Post subject: EXT ANTENNA Reply with quote
Hi dudes,
Finally after a lot of expert help from you guys in this forum, I have sucessfully pieced together a PDA GPS system I am truly happy with and got the thing running correctly (I think !). I had my fair share of problems setting it up. The manuals that come with each item are useless, I learnt more from you guys, especially David W....... Thanks.
Most of my problems, I found the answers to from this forum, but some were pure guess work and a lot of luck. Then remembering not to make the same mistakes and having to start all over again.
I'm probably some sort of expert when it comes to installing TT3.
My problem now is ......
In ST mode on my Fortuna Clip on, I get a lovely signal outside in the open within 30 seconds on a cold start, but indoors or near a window in XT, absolutely nothing, I've tried everything. I've read that I'm not the only person having this problem. I would like it working so I can setup routes at home ready for connection in the car (saves time). I thought I might buy an additional antenna to connect up to my Clip on in the house and shove the Antenna end out of the office window to get a signal indoors. (1) Does this sound cool or what else can I do (2) Do these antennas have a long enough lead i.e. something like 30 feet.
Tom Tom Go 300
Brodit mounts
23.054 (28 May 25)
