Pocket GPS World :: View topic - New address routing problem
davey
PostPosted: Thu Nov 04, 2004 12:07 am    Post subject: New address routing problem Reply with quote
I have a strnage problem when using co pilot, if i have set a destination co pilot routes me as it should do, but if I decide to cancel the route and choose a new route co pilot keeps routing me to the previous destination. Is this a problem with co pilot or is there something I am missing, I have even switched of the phone gone back into co pilot selected the new route and then it still routes me to the previous address. Can any one help with this problem
davey
lbendlin
PostPosted: Thu Nov 04, 2004 12:55 am    Post subject: Reply with quote
The Pocket PC version asks you if you want to cancel the existing route. Do you get the same message on the Smartphone?
Lutz
TomTom/TeleAtlas NAVTEQ
davey
PostPosted: Thu Nov 04, 2004 1:39 am    Post subject: Reply with quote
no
lbendlin
PostPosted: Thu Nov 04, 2004 3:42 am    Post subject: Reply with quote
you may have found a bug...
Lutz
PostPosted: Thu Nov 04, 2004 10:00 am    Post subject: Reply with quote
Hmm, never seen this myself. How are you cancelling the route ? Normally I'd go back into Edit Stops, DELETE ALL, then add a new stop then START NAVIGATING and this has always worked fine for me.
davey
PostPosted: Thu Nov 04, 2004 8:43 pm    Post subject: Reply with quote
I dont delete stops when going into edit stops as I thought if a stop was listed in there you could use that stop whenever you wished. I just select the stop I need within edit stops and click on start driving, is this perhaps where im going wrong
davey
PostPosted: Fri Nov 05, 2004 10:23 am    Post subject: Reply with quote
Ah yes, that's where you're going wrong. The stops are basically part of the journey. Thing of the stops screen as your journey, so if you have other stops listed there that you don't want, and you leave them there you will still be navigated to these. Hit Menu, (3-Delete All) and then add your destination in then click the Navigate option and you should be good to go.
kartracer
PostPosted: Fri Nov 05, 2004 11:25 am    Post subject: Reply with quote
If the Smartphone version works in a similar manner to the PocketPC one, then to achieve more or less what you have been attempting, just start a New Trip and then select a previously used stop from your Favourites (CoPilot stores the 50 most recently used stops as favourites).
Kam
PostPosted: Sat Nov 06, 2004 2:14 pm    Post subject: Reply with quote
kam, it doesn't work the same, it's different and doesn't have the saved trip feature. You can see this on the review.
Providing you delete all stops before you create your new journey as I posted previously and then ONLY add the stops required for the SmartPhone version, it will work quite nicely.
kartracer
PostPosted: Sun Nov 07, 2004 10:25 pm    Post subject: Reply with quote
Dave wrote:
... it doesn't work the same, it's different.
That's a shame. I find this feature which saves all used stops as favourites for re-use to be really useful.
Kam
fozzie63
PostPosted: Fri Nov 12, 2004 10:09 am    Post subject: Reply with quote
I think someone's getting confused here. The edit stops screen has all the stops for the current journey. Any stops listed in that screen will form part of the current route. The favourites screen does list all the previously used stops and they can be selected to be added to the current journey; if the current journey is blank then it will the next place you are directed to; if the journey already has stops, then it will be added to it.
