Pocket GPS World :: View topic - Pocket GPS Safety Camera Database Updated - Oct 30th 2004
PostPosted: Sat Oct 30, 2004 11:04 am    Post subject: Pocket GPS Safety Camera Database Updated - Oct 30th 2004 Reply with quote
The PocketGPSWorld Safety Camera Database has been updated and contains lots of new cameras including a new mobile category.
As always you can download this from here or via POI-Sync. Remember to add the new category in POI-Sync for the Mobile Cameras file if you are wanting support for mobile cameras as these have now been split away from the main central GATSO database.
omaruk
PostPosted: Sat Oct 30, 2004 11:47 pm    Post subject: Reply with quote
Great well done - keep up the good work.
Paul-m
PostPosted: Sun Oct 31, 2004 10:07 am    Post subject: Reply with quote
Great to have another update. Manay thanks.
However, im still suffering from the same problem as last time. Which is...
On my home PC i cant download the new file. i still get the contents of the old zip file. Also using POIEdit i have a similar problem. It doesnt download the new XML file so it doesnt see the new mobile file.
Ive tried clearing the cache and history in IE as well as running window washer but still nothing.
So then i connect my work laptop to the home wireless network and it all works. both zip file and POIEdit are happy. All downloaded ok. not even necessary to clear the cahe!
Any one got any ideas?
Paul
PostPosted: Sun Oct 31, 2004 11:09 am    Post subject: Reply with quote
Given your laptop works this has to be a local IE cache issue unless you run other proxy caching software or are part of a local area network that employs caching.
Flush the cache by deleting all temporary internet files, set the file cache to 50mb or so and then exit and restart IE.
Perform a file search for the Safety Camera database .zip (search Hidden files also) and delete and that are identified.
Then re-download and report back Smile
Paul-m
PostPosted: Sun Oct 31, 2004 2:38 pm    Post subject: Reply with quote
Well.... i tried all that you mentioned. i even changed the option in IE to check for a newer page each time. I deleted the temporary intyernet files, i changed the cache size, i deleted all ofline content, isearched the hard disk (hidden files visible) and deleted all copies of the file.
rebooted
still didnt work!
finally searched the registry and found a list of downloaded files.
hkey_current_user\software\microsoft\windows\currentversion\explorer\comdlg32\opensaveMRU\*
and saw the entry for the zip file. i deleted it and hey presto ...it worked.
can anyone tell me the correct way to do that Laughing Out Loud
Paul
MrRubberGloves
PostPosted: Sun Oct 31, 2004 3:09 pm    Post subject: Reply with quote
Thanks for the update.
Just one question though, not sure how popular these cameras are though but do you have plans to have a section for the Truvelo cameras?
Thumbs Up
PostPosted: Sun Oct 31, 2004 3:43 pm    Post subject: Reply with quote
Truvelo sites are already part of the Gatso database. Although they face the driver they are essentially fixed Speed Camera installations and so we thought it best to include them in that database.
The only caveat is that because they face the vehicle unlike Gatso which faces the rear of the vehicle you need to ensure your alert is set to give you sufficient warning before you enter the cameras trigger zone which will of course be before you reach the actual camera.
Reg
PostPosted: Mon Nov 01, 2004 10:49 am    Post subject: Re: Pocket GPS Safety Camera Database Updated - Oct 30th 200 Reply with quote
I cannot download any new data other than last months update (29th Sept 2004). Is the link working OK?
Tim Buxton
PostPosted: Mon Nov 01, 2004 11:48 am    Post subject: Reply with quote
I tried the link again this morining and it worked just fine for me. If you can't get tit to work for you, I could email the file to you, if you want? IT is 223Kb in .zip format.
Tim
Reg
PostPosted: Mon Nov 01, 2004 12:04 pm    Post subject: Reply with quote
Many thanks Tim, I've sent you my e-mail address (and added same to my profile).
Regards
Reg
Paul-m
PostPosted: Tue Nov 02, 2004 8:09 am    Post subject: Reply with quote
I should add that the difference between my 2 mschines is that the one that works is XP Professonal SP1 and the one that doesnt work without the hack above is XP Professional SP2
Paul
icsys
PostPosted: Tue Nov 02, 2004 10:36 am    Post subject: Reply with quote
I have XP SP2 which performs without errors so I would discount that as causing your problem.
Who is your ISP?
It is not uncommon for certain ISP's to cache websites to speed up your browsing experience.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
icsys
PostPosted: Tue Nov 02, 2004 10:39 am    Post subject: Reply with quote
**edit**
But then again it seems strange that your laptop can download when connected to the same network (same ISP?).
In the past when I have experienced this phenomenon I have used an alternative browser such as Netscape to flush the new pages through.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
ttrevor
PostPosted: Tue Nov 02, 2004 10:42 am    Post subject: Reply with quote
Thanks very much ,all downloaded ,Brilliant , :D thanks for all your hard work once again
regards trevor
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
Paul-m
PostPosted: Tue Nov 02, 2004 2:13 pm    Post subject: Reply with quote
I must admit im stumped by it really.
It has to be the PC config somewhere. but i assumed that using window washer to delete everything as well as manually searching the PC to delete any existing files would have done it.
The PC was recently completely re-installed as i had a new hard disk and motherboard.
Everytime i tried to download it it seemed to be working but always reported the file size as 172K. most odd!
I even tried POIEdit but this didnt even see the new XML file!
So i connected the company laptop using WiFi to the same network and it just worked without anything at all!
must be some wierd registry key set to make life difficult!
Paul
22.062 (12 Jun 24)
