Pocket GPS World :: View topic - Ipaq 2210 Power and Data cable
longwori
PostPosted: Mon Oct 06, 2003 1:47 pm    Post subject: Ipaq 2210 Power and Data cable Reply with quote
Hi can anyone tell me if the GQ38P Combo Compaq Ipaq 3800 Interface cable will work with the new 2210?
Ian.
Pc-Mobile
PostPosted: Tue Oct 07, 2003 1:21 pm    Post subject: Reply with quote
Yes.
38xx/39xx/54xx/55xx/22xx are all compatible.
19xx series is the odd one from recent Ipaq ranges as they do not have serial port so cannot connect any GPS via the bottom port.
shavermcspud
PostPosted: Fri Oct 29, 2004 2:20 pm    Post subject: re Reply with quote
its not strictly true with regards to the 2210 series. if you use the cable from the older series ipaq and rotate it 180 degress it will fit in and providing you have the dual usb/serial sync cable you can get serial i/o in to the newer 2210 units, im doing exactly that using and older series cradle ripped apart for the connector. works a treat.
shavermcspud
PostPosted: Fri Oct 29, 2004 2:22 pm    Post subject: oops Reply with quote
cancel that i read it wrong you said 1900 series odd one out really sorry, going back in my hole now.
