O Occasional Visitor
Posted: Wed Oct 27, 2004 8:22 am Post subject: 2210 & HI303E Sats will not lock |
I am having trouble with my GPS system, i have a 2210 PDA and a CF GPS (Haicom HI-303E). when you start the GPS Satellite system (Tom Tom) and look at how strong your signal is, it will pick up 3,4 or 5 satellites but after about 5 seconds they will drop off but then they will came back (outdoors) it will keep on doing this but wont lock on, it is the same if i run the Haicom software (GPS Info), I have had it working for a short while in the beginning but for some reason it has stop locking on, i thought it might be a software conflict so i hard reset my PDA but still the same.
Help!!
Has anyone come across this before. |
Dave Frequent Visitor
Posted: Wed Oct 27, 2004 8:54 am Post subject: |
Hold the PPC horizontal and see if that makes a difference.
Also does it ever get a lock outside ? If you're getting 4 or more sats then you should obtain a 3D fix. If sat signals are dropping off when you go inside the car you may have an athermic windscreen and require a re-radiating antenna. |
Posted: Wed Oct 27, 2004 9:10 am Post subject: 2210 & HI - 303E not locking |
Thanks for a quick responce.
I have tried it outside in clear line of sky and moved the CF GPS in various positions but unfortunatly i still can not get it to lock.
Do you think it may be faulty
Have you got any other ideads???? |
kiwiruss Occasional Visitor
Posted: Fri Nov 12, 2004 10:07 pm Post subject: same thing here too |
My ipaq's a 5455 but the gps is the haicom 303e and
although its detecting 4 sats at least, its not getting a lock, even after minutes and minutes.
Im thinking mine is dud too. |
Posted: Mon Dec 06, 2004 9:05 pm Post subject: byby h303e ello h303s |
Ive replaced my h303e with the h303s and the difference is amazing.
Its working flawlessly, getting a cold start fix in around 30 seconds and seeing 6-8 satellites regularly.
Costs a little more but its worth it. |
