owls Occasional Visitor
Posted: Mon Oct 25, 2004 6:34 pm Post subject: tomtom go antenna |
I have a ford focus with heated screen and ttg works OK. In dads BMW with normal screen it works so much better.
Looking at the bottom of my ttg, am I correct in assuming the round plug at the back is for the antenna?
I have a snooper s6 with external antenna, unfortunately the antenna plug is too small to fit ttg. If I could get an adaptor to fit would this antenna work? and does anyone know, is there such an adaptor and if there is where can I get one from?
Hope this lot is not too tricky.
Oliver |
MrRubberGloves Regular Visitor
Joined: May 09, 2004 Posts: 163 Location: Blackpool, England.
Posted: Mon Oct 25, 2004 6:58 pm Post subject: |
I'm pretty sure if you want to use an antenna with the TT Go then you have to buy the one where it replaces half of the windscreen mount. There are plenty of threads on here regarding the re-radiating antenna. |
MikeB Frequent Visitor
Posted: Tue Oct 26, 2004 8:49 am Post subject: |
I think the connector that you are referring to is a power connector, The one right on the bottom behind the two slot connectors is marked +5v 2A which implies pover not signal. _________________ Mike Barrett |
Eldar Pocket GPS Moderator
Posted: Tue Oct 26, 2004 10:12 am Post subject: |
Mike
Oliver is right - the "round" plug is a connector for external antenna. |
