Pocket GPS World :: View topic - tomtom go antenna
tomtom go antenna
owls
PostPosted: Mon Oct 25, 2004 6:34 pm    Post subject: tomtom go antenna Reply with quote
I have a ford focus with heated screen and ttg works OK. In dads BMW with normal screen it works so much better.
Looking at the bottom of my ttg, am I correct in assuming the round plug at the back is for the antenna?
I have a snooper s6 with external antenna, unfortunately the antenna plug is too small to fit ttg. If I could get an adaptor to fit would this antenna work? and does anyone know, is there such an adaptor and if there is where can I get one from?
Hope this lot is not too tricky.
Oliver
MrRubberGloves
PostPosted: Mon Oct 25, 2004 6:58 pm    Post subject: Reply with quote
I'm pretty sure if you want to use an antenna with the TT Go then you have to buy the one where it replaces half of the windscreen mount. There are plenty of threads on here regarding the re-radiating antenna.
PostPosted: Tue Oct 26, 2004 8:49 am    Post subject: Reply with quote
I think the connector that you are referring to is a power connector, The one right on the bottom behind the two slot connectors is marked +5v 2A which implies pover not signal.
Eldar
PostPosted: Tue Oct 26, 2004 10:12 am    Post subject: Reply with quote
Mike
Oliver is right - the "round" plug is a connector for external antenna.
22.064 (26 Jun 24)
