Pocket GPS World :: View topic - active sync
active sync
dunno
PostPosted: Sun Oct 24, 2004 8:52 pm    Post subject: active sync Reply with quote
since installing the new service package i have been unable to sync pc ppc (well to be more honest it's been ages since i tried but is before i installed the update).i can see it on the pc in my computer but if i try and explore there is nothing there also i have tried restalling it up but it doesn't want to know
ipaq2210 2003 & windows xp home linked via cradle
any ideas will be appreciated ,thanks
PostPosted: Mon Oct 25, 2004 1:13 am    Post subject: Reply with quote
that's a common issue with XP, especially after SP2. Try reinstalling ActiveSync 3.7.1
PostPosted: Mon Oct 25, 2004 7:25 am    Post subject: Reply with quote
3.7.1 is the problem, downgrade to 3.7 or below and it will be okay. There's download links on our download menu to various ActiveSync versions.
It's a known Microsoft bug that Microsoft STILL hasn't fixed.
icsys
PostPosted: Mon Oct 25, 2004 12:12 pm    Post subject: Reply with quote
Thats strange?
I have SP2 installed and I use active Sync 3.7.1
I can sync to the PPC and everything works fine with no problems at all.
In fact after reading horror stories about SP2 I didn't want o install it but as I had automatic updates switched on and SP2 had started to install automatically I decided to let it finish. Nedless to say I needn't have worried as I have not experienced any issues with it at all.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Tim Buxton
PostPosted: Mon Oct 25, 2004 12:26 pm    Post subject: Reply with quote
I too have Win XP (Pro) with SP2 installed. I have ActiveSync 3.7.1 (Build 4034) and like icsys have had no problems.
Tim
PostPosted: Mon Oct 25, 2004 2:11 pm    Post subject: Reply with quote
yeah, it works fine until you start using more than one pocket pc on the same active sync PC. AS gets confused after a while and doesn't show the folders any more. Interestingly enough the way via the "My Computer . Mobile Device" may still work, and the way via the dev tools (Remote File Viewer WILL still work. Sometimes killing wcescomm.exe helps, sometimes a rebot, sometimes just patience.
Tim Buxton
PostPosted: Mon Oct 25, 2004 2:18 pm    Post subject: Reply with quote
Sorry Lutz, but my 3970 and 5555 are definitely different and both work just fine on the same PC. I guess that my situation is the exception that proves the rule....
Tim
PostPosted: Mon Oct 25, 2004 2:28 pm    Post subject: Reply with quote
Do you have your PC setup to have partnerships with both devices?
I can't afford that because I use multiple PCs to connect to multiple pocket pcs, and have set AS to automatically only accept guest connections - maybe that's contributing, too.
Tim Buxton
PostPosted: Mon Oct 25, 2004 2:37 pm    Post subject: Reply with quote
Yes I do.
Tim
dunno
PostPosted: Mon Oct 25, 2004 3:10 pm    Post subject: Reply with quote
thanks for the replies ,yes i did try go back to 3.7 and it still didn't work on my pc ,so i reinstalled 3.7.1 ,i'll go back to the old 1 and try a few more times and see what happens
icsys
PostPosted: Mon Oct 25, 2004 3:25 pm    Post subject: Reply with quote
Make sure your cradle is unplugged from your PC when installing activeSync otherwise this could cause you problems synchronising with the PDA.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
dunno
PostPosted: Sat Nov 13, 2004 4:35 pm    Post subject: Reply with quote
i ended up doing a go back on my ppc & now it works ,so it must have been something wrong on my ppc
22.055 (29 May 24)
