GoFast Occasional Visitor
Posted: Wed Oct 20, 2004 12:12 am Post subject: TomTom Go and Safty camera POI database |
Has anyone been successfull in activating this add-on on their TomTom Go?
I copied the bmp and ov2 files to the correct directory and done an activation. When maintain POI says nothing in there + Go keeps re-booting on its own during normal operation.
Any input will be met with gratitude...
GoFast. |
sgould Frequent Visitor
Posted: Wed Oct 20, 2004 4:55 pm Post subject: |
The ,ov2 and .bmp should be in the GB map folder.
I think most people have done this successfully. Are you short of memory? You may be if you are still on the 128Mb SD card and have not deleted some voices. |
Eldar Pocket GPS Moderator
Posted: Wed Oct 20, 2004 5:00 pm Post subject: Re: TomTom Go and Safty camera POI database |
GoFast wrote: | Hi
GoFast. |
What s/w version are you running? Have you upgraded to version 4.40? |
Posted: Wed Oct 20, 2004 5:31 pm Post subject: |
Thanks for your posts. I am running S/W ver 4.40. I am on a 128M SD but only use the various English voices 4 or 5 in all. After copying the files to the GB map Dir the SD still shows about 16M free......
Is there any order to do things when installing app. What I did was install the application & voices then the map then copy ov2&bmp's and then activate, is this the correct order?
GoFast. |
Posted: Wed Oct 20, 2004 5:41 pm Post subject: |
Can you possibly list your actions since you bought the unit. Was it working properly when you got it out of the box? Why did you need to activate the maps? |
Posted: Wed Oct 20, 2004 5:56 pm Post subject: |
The unit worked fine when I bought it. Then I thought I needed to upgrade to 4.40, because I saw it on the net not knowing that it was shipped already with that version, so I guess I corrupted the whole installation because the Go wouldn't boot up and indicated an SD error etc'. So I had to install it all from new....Also I am new to GPS devices...
As is now it works fine.
GoFast. |
Posted: Thu Oct 21, 2004 10:06 am Post subject: |
I'm at a loss here. You are saying that the only thing which doesn't wok is downloadable POIs, which you correctly installed in the maps directory. Perhaps somebody else will know a way to cure the problem. |
Posted: Thu Oct 21, 2004 11:48 am Post subject: |
My thoughts are as follows:
1. Either the POI is Navigator compatible but not GO
2. A memory problem as mentioned before.
The latter seems more plausable since all computers tend to crash when they run out of memory. I''l try again after install larger memory card.
Thanks for all your help so far.
GoFast. |
Posted: Sat Oct 23, 2004 3:33 pm Post subject: |
Ok, got a 512M memory card, now every thing works fine including the various camera POI's. I was also able to include the Eropian map in there.
I hope this experience/tip will be helpful to others in the future, thanks for everyones help.
GoFast. |
Nazz Occasional Visitor
Posted: Mon Oct 25, 2004 11:08 pm Post subject: |
Hello there you guys :D
This is my first post and I am a newbie in the world of TTG. Just got mine recently with s/w v4.4 preloaded and no problem installing the "safety camera" POIs. I have a query and cant see it covered anywhere else. Hope you dont mind me asking.
I dont have any trouble "editing" the POI database. In fact I have been able to delete cameras that are not there anymore as well as insert new ones (all done on TTG itself)
My question is, although the TTG shows the icon of the newly inserted camera, it does not give an alarm warning to the new cameras that I have inserted. How can I get it to beep on these newly added camera sites?
Cheers |
Posted: Tue Oct 26, 2004 12:43 am Post subject: |
Choose the 'maintain PoI' and tick the box for the "Warn when......" You get to choose the sound from a selection of bells and whistles. |
Posted: Tue Oct 26, 2004 8:03 am Post subject: |
sgould wrote: | Choose the 'maintain PoI' and tick the box for the "Warn when......" You get to choose the sound from a selection of bells and whistles. |
Thank you for your reply. I have already tried that. May I just clarify that the beeps still exists for the base cameras but I canrt get it to beep for newly added cameras. Am I doing something wrong? Is there a trick to this? |
MikeB Frequent Visitor
Posted: Tue Oct 26, 2004 9:17 am Post subject: |
When you added the new cameras I am assuming that they were placed into the existing database, and not into a new POI database.
If this is the case then the most likely cause of the lack of detection is that you have set them for "on route" notification and the POI is too far away from the road (or on the wrong side) to register.
Dont forget to submit your database of new cameras to the site to allow us to keep them as up to date as possible. _________________ Mike Barrett |
BanziBarn Regular Visitor
Posted: Tue Oct 26, 2004 12:46 pm Post subject: |
The ones I added beep ok. |
Posted: Tue Oct 26, 2004 5:34 pm Post subject: |
I am quite intrigued with this topic. If you pass by a camera that does not come up from the db, how do you go about inserting and adding it. Are you supposed to stop and lookup the co-ordinates, when I went to maintain POI it seems to want an address.
Maybe I have it all arse about face in this instance but any help to clarify will be appreciated.
GoFast |
