toyracer69 Lifetime Member
Posted: Mon Jun 03, 2024 3:40 pm Post subject: STA Issues |
Hi Leo, I'm having a few issues with my STA app on my Google 8 Pro phone.
For a little while the app will drop off the front screen, on its own, even though all settings haven't changed and it shows that the app is still doing something as the app tile has a dot on it.
Also it has stopped warning me, as I get closer to a camera (Bleeps), if I am over the speed limit of said camera. I use it on the speed setting and the dial goes red but it does not bleep at me like it used to. Again all settings appear to be as they should.
Any idea what I can do to get it back up and running as it did?
Pete |
Leo_A Regular Visitor
Posted: Tue Jun 04, 2024 8:23 am Post subject: Re: STA Issues |
toyracer69 wrote: | For a little while the app will drop off the front screen, on its own, even though all settings haven't changed, and it shows that the app is still doing something as the app tile has a dot on it. |
I noticed something similar two days ago, but I was switching between other apps, and I thought I did something wrong. However, it looked strange, I'v never seen such behavior before.
I also use 8 Pro, will keep watching, don't know what was this.
The issue is reproducible? I mean this happens every time you use the app. |
Posted: Tue Jun 04, 2024 4:31 pm Post subject: Re: STA Issues |
Leo_A wrote: | toyracer69 wrote: | For a little while the app will drop off the front screen, on its own, even though all settings haven't changed, and it shows that the app is still doing something as the app tile has a dot on it. |
Yes every time I use STA..... |
Kremmen Pocket GPS Verifier
Posted: Tue Jun 04, 2024 4:36 pm Post subject: |
FYI, my Samsung phone seems OK with STA _________________ DashCam:
Viofo A119 V3 |
Posted: Thu Jun 06, 2024 9:13 am Post subject: |
Also the PGPSWorld updates have stopped since the 1st of June. I can manually add them onto my phone though.......
It's just like the old days. |
Posted: Fri Jun 07, 2024 6:21 am Post subject: |
toyracer69 wrote: | Also the PGPSWorld updates have stopped since the 1st of June. I can manually add them onto my phone though.......
And now its working again. The only change I did was the option to check on start up.....
Not sure if that was all it needed but I've still got the other two issues, the not warning one is the one I'd like to get fixed though..... |
Posted: Tue Jun 18, 2024 8:42 pm Post subject: |
Looks like the latest update has virtually stopped the app from dropping off the screen, whilst in use, but still not getting any verbal warnings (Increasing bleeps or a spoken warning) that I'm travelling too fast as I approach a camera..... |
Posted: Mon Jun 24, 2024 6:37 am Post subject: |
Just a quick update on my STA issues.
The app shutting down is still there but no as often but it doesn't have the dot on the app tile as before.
Also the bleeping warnings, if travelling too fast, still do not work and does not work on my girlfriends S22 either....... |
The app shutting down is still there but not as often but it doesn't have the dot on the app tile as before.
Also the bleeping warnings, if travelling too fast, still do not work...... |
Posted: Mon Jun 24, 2024 3:15 pm Post subject: |
toyracer69 wrote: | Just a quick update on my STA issues.
I have finally found crash report in Google Play Dev Console that came from Pixel 8 Pro.
Crash happened when user of the device was driving between SPECS, avg speed control was active in that moment.
Could it be your case? |
Posted: Tue Jun 25, 2024 6:49 am Post subject: |
Leo_A wrote: | toyracer69 wrote: | Just a quick update on my STA issues.
I'm sure it has but also at random times as well..... |
Posted: Wed Jun 26, 2024 6:16 am Post subject: |
It shut down on me, on my way into work this morning.
I was just passing camera and was announcing it when it shut down, half way through what it was saying.
Also when I went back into the app there was no sound but I shut it back down and then restarted it, But this is quite normal. Still no warning bleeps increasing if too fast.
Also it was a standard Gatso camera, so not a Specs one.... |
Posted: Wed Jul 03, 2024 8:18 am Post subject: |
Downloaded the latest update and it shut down this morning on my way into work. No where near any cameras, etc...
Still not increasing its bleeps if travelling too fast to a camera. |
Posted: Wed Jul 03, 2024 1:26 pm Post subject: |
Very odd
Must be phone related as my Sammy 23+ is working perfectly still _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Jul 05, 2024 8:49 am Post subject: |
Kremmen wrote: | Very odd
Must be phone related as my Sammy 23+ is working perfectly still |
Maybe but I tried it on my girlfriends S22 and it does the same as mine..... |
