Kremmen Pocket GPS Verifier
Posted: Thu Jun 06, 2024 4:26 am Post subject: |
Quite early on in the help file I'm sure there is reference to copy your choice of the WAV and BMP files from the download package
Those supplied files are already named correctly
I say 'I'm sure' as it will be a couple more months before my PC is up and running due to a house move
In the meantime I'm limited to an Android tablet
Managed to embed the relevant page :
 _________________ DashCam:
Viofo A119 V3 |
Clingy Occasional Visitor
Posted: Thu Jun 06, 2024 9:06 am Post subject: |
OK Thanks again |
cliffbrown Lifetime Member
Posted: Sat Jun 15, 2024 7:22 am Post subject: |
hi all I have changed my satnav Camper 780 and the bmp are only showing small though I have the 44x44 as used on my previous camper 760, is there a work around to increase the size?
thanks in advance |
tankerman10 Lifetime Member
Posted: Sat Jun 15, 2024 12:01 pm Post subject: |
I've been using Version 2016.06.01.45 successfully with UK speed zoned complete database for many years - transferred to my BMW Nav 5 and Nav 6 using POI Loader. I'm thinking of adding Europe speed zoned complete and think it would be better to unzip to a separate folder. I've downloaded and unzipped the PGPSW file using the programme but all the filenames contain numbers, so cannot be processed. How can I get round this? |
Posted: Sat Jun 15, 2024 2:48 pm Post subject: |
The Converter is only designed to handle the UK database with 20 to 70 mph cameras
Your only solution is to use a different working folder for the EU cameras and just process them using POILoader _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Jun 15, 2024 8:07 pm Post subject: |
Kremmen wrote: | The Converter is only designed to handle the UK database with 20 to 70 mph cameras
Your only solution is to use a different working folder for the EU cameras and just process them using POILoader |
Thanks. |
Posted: Sun Jun 16, 2024 3:57 am Post subject: |
Of course the end result is that you will have 2 GPI files but that works fine _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Jun 16, 2024 7:32 am Post subject: |
Kremmen wrote: | Of course the end result is that you will have 2 GPI files but that works fine |
T5YOB Lifetime Member
Posted: Thu Jul 11, 2024 12:03 pm Post subject: |
I'm having trouble converting the European speed camera files to the Garmin device, I unzip the Europe speed camera and sound and image files they all go green, but it won't let me press the process button and comes up with unexpected Gatso File found, do you want to delete or cancel and if you press yes and eventually end up deleting every file out of the green boxes, any help? |
Posted: Thu Jul 11, 2024 1:21 pm Post subject: |
The Converter is not designed to accept European KPH databases
You'll need to use stock CSV and the POILoader _________________ DashCam:
Viofo A119 V3 |
Posted: Thu Jul 11, 2024 2:53 pm Post subject: |
Kremmen wrote: | The Converter is not designed to accept European KPH databases
You'll need to use stock CSV and the POILoader |
So I just download the Europe file with the Voice files and then unzip put them in a folder and just download straight to the device? Will they still work ok ? |
Posted: Thu Jul 11, 2024 3:50 pm Post subject: |
Yes, as long as you allow POILoader to use a different filename _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Jul 15, 2024 7:47 am Post subject: |
What you can do is have other cameras in a sub folder
The Converter will only process the folder it's pointing to but POILoader will dig deeper and process both GPX and CSV in one operation giving you just one GPI file _________________ DashCam:
Viofo A119 V3 |
