Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 73, 74, 75
PostPosted: Thu Jun 06, 2024 4:26 am    Post subject: Reply with quote
Quite early on in the help file I'm sure there is reference to copy your choice of the WAV and BMP files from the download package
Those supplied files are already named correctly
I say 'I'm sure' as it will be a couple more months before my PC is up and running due to a house move
In the meantime I'm limited to an Android tablet
Managed to embed the relevant page :
Lets be careful out there !
Clingy
PostPosted: Thu Jun 06, 2024 9:06 am    Post subject: Reply with quote
OK Thanks again
cliffbrown
PostPosted: Sat Jun 15, 2024 7:22 am    Post subject: Reply with quote
hi all I have changed my satnav Camper 780 and the bmp are only showing small though I have the 44x44 as used on my previous camper 760, is there a work around to increase the size?
thanks in advance
tankerman10
PostPosted: Sat Jun 15, 2024 12:01 pm    Post subject: Reply with quote
I've been using Version 2016.06.01.45 successfully with UK speed zoned complete database for many years - transferred to my BMW Nav 5 and Nav 6 using POI Loader. I'm thinking of adding Europe speed zoned complete and think it would be better to unzip to a separate folder. I've downloaded and unzipped the PGPSW file using the programme but all the filenames contain numbers, so cannot be processed. How can I get round this?
PostPosted: Sat Jun 15, 2024 2:48 pm    Post subject: Reply with quote
The Converter is only designed to handle the UK database with 20 to 70 mph cameras
Your only solution is to use a different working folder for the EU cameras and just process them using POILoader
tankerman10
PostPosted: Sat Jun 15, 2024 8:07 pm    Post subject: Reply with quote
Thanks.
PostPosted: Sun Jun 16, 2024 3:57 am    Post subject: Reply with quote
Of course the end result is that you will have 2 GPI files but that works fine
tankerman10
PostPosted: Sun Jun 16, 2024 7:32 am    Post subject: Reply with quote
T5YOB
PostPosted: Thu Jul 11, 2024 12:03 pm    Post subject: Reply with quote
I'm having trouble converting the European speed camera files to the Garmin device, I unzip the Europe speed camera and sound and image files they all go green, but it won't let me press the process button and comes up with unexpected Gatso File found, do you want to delete or cancel and if you press yes and eventually end up deleting every file out of the green boxes, any help?
PostPosted: Thu Jul 11, 2024 1:21 pm    Post subject: Reply with quote
The Converter is not designed to accept European KPH databases
You'll need to use stock CSV and the POILoader
T5YOB
PostPosted: Thu Jul 11, 2024 2:53 pm    Post subject: Reply with quote
So I just download the Europe file with the Voice files and then unzip put them in a folder and just download straight to the device? Will they still work ok ?
PostPosted: Thu Jul 11, 2024 3:50 pm    Post subject: Reply with quote
Yes, as long as you allow POILoader to use a different filename
PostPosted: Mon Jul 15, 2024 7:47 am    Post subject: Reply with quote
What you can do is have other cameras in a sub folder
The Converter will only process the folder it's pointing to but POILoader will dig deeper and process both GPX and CSV in one operation giving you just one GPI file
CDK
PostPosted: Wed Aug 06, 2025 4:08 pm    Post subject: Looking for link for update of CSV to GPS Convertor? Reply with quote
Just returned to using the CSV to GPS Convertor on my Garmin after some time.
The version I have on my PC is: version 22.12.07.16
Though this works fine, I see there is a message that there is an updated version 2024.10.25.18.
Where can I find the link to download that please?
Regards
CDK
PostPosted: Wed Aug 06, 2025 4:21 pm    Post subject: Reply with quote
If you go to the first page, first post of this thread both the V1 and V2 links are both there
Page 75 of 75
23.091 (03 Sep 25)
