Pocket GPS World :: View topic - STA Issues
STA Issues
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA)
toyracer69
PostPosted: Mon Jun 03, 2024 3:40 pm    Post subject: STA Issues Reply with quote
Hi Leo, I'm having a few issues with my STA app on my Google 8 Pro phone.
For a little while the app will drop off the front screen, on its own, even though all settings haven't changed and it shows that the app is still doing something as the app tile has a dot on it.
Also it has stopped warning me, as I get closer to a camera (Bleeps), if I am over the speed limit of said camera. I use it on the speed setting and the dial goes red but it does not bleep at me like it used to. Again all settings appear to be as they should.
Any idea what I can do to get it back up and running as it did?
Pete
Leo_A
PostPosted: Tue Jun 04, 2024 8:23 am    Post subject: Re: STA Issues Reply with quote
toyracer69 wrote:
For a little while the app will drop off the front screen, on its own, even though all settings haven't changed, and it shows that the app is still doing something as the app tile has a dot on it.
I noticed something similar two days ago, but I was switching between other apps, and I thought I did something wrong. However, it looked strange, I'v never seen such behavior before.
I also use 8 Pro, will keep watching, don't know what was this.
The issue is reproducible? I mean this happens every time you use the app.
toyracer69
PostPosted: Tue Jun 04, 2024 4:31 pm    Post subject: Re: STA Issues Reply with quote
Yes every time I use STA.....
PostPosted: Tue Jun 04, 2024 4:36 pm    Post subject: Reply with quote
FYI, my Samsung phone seems OK with STA
toyracer69
PostPosted: Thu Jun 06, 2024 9:13 am    Post subject: Reply with quote
Also the PGPSWorld updates have stopped since the 1st of June. I can manually add them onto my phone though.......
It's just like the old days. Laughing
toyracer69
PostPosted: Fri Jun 07, 2024 6:21 am    Post subject: Reply with quote
And now its working again. The only change I did was the option to check on start up.....
Not sure if that was all it needed but I've still got the other two issues, the not warning one is the one I'd like to get fixed though..... Wink
toyracer69
PostPosted: Tue Jun 18, 2024 8:42 pm    Post subject: Reply with quote
Looks like the latest update has virtually stopped the app from dropping off the screen, whilst in use, but still not getting any verbal warnings (Increasing bleeps or a spoken warning) that I'm travelling too fast as I approach a camera.....
toyracer69
PostPosted: Mon Jun 24, 2024 6:37 am    Post subject: Reply with quote
Just a quick update on my STA issues.
The app shutting down is still there but no as often but it doesn't have the dot on the app tile as before.
Also the bleeping warnings, if travelling too fast, still do not work and does not work on my girlfriends S22 either....... Confused
toyracer69
The app shutting down is still there but not as often but it doesn't have the dot on the app tile as before.
Also the bleeping warnings, if travelling too fast, still do not work...... Confused
Leo_A
PostPosted: Mon Jun 24, 2024 3:15 pm    Post subject: Reply with quote
I have finally found crash report in Google Play Dev Console that came from Pixel 8 Pro.
Crash happened when user of the device was driving between SPECS, avg speed control was active in that moment.
Could it be your case?
toyracer69
PostPosted: Tue Jun 25, 2024 6:49 am    Post subject: Reply with quote
I'm sure it has but also at random times as well.....
toyracer69
PostPosted: Wed Jun 26, 2024 6:16 am    Post subject: Reply with quote
It shut down on me, on my way into work this morning.
I was just passing camera and was announcing it when it shut down, half way through what it was saying. Confused
Also when I went back into the app there was no sound but I shut it back down and then restarted it, But this is quite normal. Still no warning bleeps increasing if too fast. Wink
Also it was a standard Gatso camera, so not a Specs one....
toyracer69
PostPosted: Wed Jul 03, 2024 8:18 am    Post subject: Reply with quote
Downloaded the latest update and it shut down this morning on my way into work. No where near any cameras, etc...
Still not increasing its bleeps if travelling too fast to a camera.
PostPosted: Wed Jul 03, 2024 1:26 pm    Post subject: Reply with quote
Very odd
Must be phone related as my Sammy 23+ is working perfectly still
toyracer69
PostPosted: Fri Jul 05, 2024 8:49 am    Post subject: Reply with quote
Kremmen wrote:
Very odd
Maybe but I tried it on my girlfriends S22 and it does the same as mine.....
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA) All times are GMT + 1 Hour
23.054 (28 May 25)
