Pocket GPS World :: View topic - PGPSW Cameras to Garmin (Spoon Feed Version)
Goto page Previous  1, 2
PostPosted: Fri Jul 10, 2020 9:18 am    Post subject: Reply with quote
Well T5YOB, please just try it and report back on success or otherwise. (There is a simulator on the Garmin, so you don't even need to go out)
T5YOB
PostPosted: Fri Jul 10, 2020 5:12 pm    Post subject: Reply with quote
Never knew you could do this, never really fiddled about with the Sat Nav that much tbh, but tried it via this way and all works fine, it's nice having spoken speed camera alerts now on the nav.
PostPosted: Sat Jul 11, 2020 5:34 pm    Post subject: Reply with quote
Result. And just in case, Neither did I until someone who's username starts with either K or s pointed me at it.
Next thing is to have a go at Kremmen's CSV to GPX converter. Quite a steep learning curve, but well wort it.
stringman
PostPosted: Wed Feb 28, 2024 12:28 pm    Post subject: Reply with quote
Hi all
I have a Garmin Zumo 390.
I previously (several years ago) downloaded the camera database from here.
I seem to remember having to make all sorts of changes in Excel before I could load them ( though the memory is a bit hazy so I may have it wrong!)
The last database warned me when there was a camera and, if I was above the limit, warned me again.
Is this the same database?
I read the sticky and followed the instructions and the data has transferred but it seems like a different process.
So I wondered if A) I have the right database B) If I have done it correctly?
Many Thanks in advance
PostPosted: Wed Feb 28, 2024 1:00 pm    Post subject: Reply with quote
Hi stringman
You shouldn't need to change any of the data itself but you may have manually changed the alert icons?
The instructions for your device are here: https://www.pocketgpsworld.com/uksafetycameras-garmin.php
Or you can use the steps at the start of this thread.
Page 2 of 2
23.084 (27 Aug 25)
