walkabout Occasional Visitor
Posted: Sun Feb 13, 2022 3:27 pm Post subject: Which Database for KIA Sportage? |
Hi Guys,
I have a 2016 KIa Sportage.
The Satnav I believe as mentioned in the manual is Tom Tom based.
It can take custom POI's,, but only gpx or kml.
Which data base could I use?
I also believe it's a Win CE system?
Thanks |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15436 Location: Bradford, West Yorkshire
Posted: Mon Feb 14, 2022 8:42 pm Post subject: |
'TomTom' will likely be the mapping rather than the navigation itself.
We have both GPX and KML available. Look for 'Garmin - Other' and you can find GPX there.
MaFt |
Posted: Fri Feb 18, 2022 2:28 pm Post subject: |
MaFt wrote: | 'TomTom' will likely be the mapping rather than the navigation itself.
MaFt |
Hi MaFt,
I had a look and under Garmin there is no "other" in the Garmin or GPX or KML listed, only CSV?
Unless I'm being a bit thick and can't see it?
Mark |
Kremmen Pocket GPS Verifier
Posted: Fri Feb 18, 2022 5:46 pm Post subject: |
Scroll down the list, It's under Excel _________________ Lets be careful out there ! |
Posted: Wed Feb 23, 2022 6:47 pm Post subject: |
Thanks guys,
Manged to find the download and the head unit took in some of the POI's.
It seems the Sportage can only have 5000 entries and the database is currently 9,450 without pmobile.
So back to the drawing board.
Any ideas, or should I just give up?
Is there a way of just selecting say South of England or Birmingham down?
Mark |
Posted: Thu Feb 24, 2022 6:49 am Post subject: |
The other thing to check, as many have found, is - can you set these POI's as cameras, that require an advance warning, or just POI's you can only navigate to. _________________ Lets be careful out there ! |
Posted: Tue Mar 01, 2022 1:43 pm Post subject: |
You'd need to order the POIs in the file by Latitude and then remove anything higher than, say 52.48
MaFt |
Posted: Thu Mar 03, 2022 9:31 am Post subject: |
Thanks MaFt,
I will give that a try.
Mark |
pitchnearly Occasional Visitor
Posted: Tue Jun 06, 2023 2:37 am Post subject: |
MaFt wrote: | You'd need to order the POIs in the file by Latitude and then remove anything higher than, say 52.48
MaFt |
I tried and found it. Thank you very much. |
