Pocket GPS World :: View topic - Zumo XT and Audio Voice alarms on PGPSW.com Still working
Clingy
PostPosted: Thu May 18, 2023 12:18 pm    Post subject: Zumo XT and Audio Voice alarms on PGPSW.com Still working Reply with quote
Hi Folks been using many years from 3 Garmins ago, and alway got the voice warning to work. Now I am getting nothing. Can someone with an XT confirm it works. I used to get it set to announce once too.
PostPosted: Thu May 18, 2023 12:32 pm    Post subject: Reply with quote
Run through this and check you have Sox installed
https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=97158
Clingy
PostPosted: Thu May 18, 2023 2:55 pm    Post subject: Reply with quote
Thanks Kremmen, i tried that and it does not work yet. My Subscription has run out so i am using old files. I did not want to subscribe again just to have it now work. Are you running an XT?
PostPosted: Thu May 18, 2023 3:59 pm    Post subject: Reply with quote
No, but from posts here all Garmin's work the same way with regard to POI's.
When you run POILoader do you get any error message ?
The only other thing I can thing of is ..... are you using a folder for your PGPSW files that is just a straight word with no apostrophes or gaps ?
For example, on the unit, if the filename is say PGPSW.gpi, that's fine but if it's PGPSW's.gpi then that causes problems.
Clingy
PostPosted: Thu May 18, 2023 5:20 pm    Post subject: Reply with quote
Thanks Again Kremmen,
I renamed everything and it does not work. i used old file and that does work so some kind of issue there. Bottom line is I can now subscribe again and get moving.
PostPosted: Fri May 19, 2023 4:44 am    Post subject: Reply with quote
You could try downloading my CSV Converter as that has error checking that may highlight a problem.
https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=91951
Clingy
PostPosted: Fri May 19, 2023 8:51 am    Post subject: Reply with quote
Thanks, For quite involved reasons i would not be able to use that. I think I am there now..unti the next error ! ;-)
PostPosted: Fri May 19, 2023 9:38 am    Post subject: Reply with quote
Smile
Clingy
PostPosted: Wed May 24, 2023 2:06 pm    Post subject: Reply with quote
Thanks again kremmen, I confirm it works. Voice is not right and repeats but I shall quit while ahaead
PostPosted: Wed May 24, 2023 3:28 pm    Post subject: Reply with quote
Thumbs Up
