Coaster2 Lifetime Member
Posted: Mon Dec 27, 2021 8:49 pm Post subject: POIS |
Can anyone tell me how to remove points of interest from a Garmin Nuvi 65 please. |
Kremmen Pocket GPS Verifier
Posted: Tue Dec 28, 2021 5:17 am Post subject: |
Connect the unit to a PC and look in the POI folder. _________________ DashCam:
Viofo A119 V3 |
Posted: Tue Dec 28, 2021 10:19 am Post subject: |
Kremmen wrote: | Connect the unit to a PC and look in the POI folder. |
Thank you. I'll try that. Worked a treat. Many thanks. |
Posted: Thu Dec 30, 2021 3:20 pm Post subject: |
My mistake. All I managed to do was remove the speed cameras. |
Posted: Thu Dec 30, 2021 4:01 pm Post subject: |
Yes, you do need to identify the correct file. _________________ DashCam:
Viofo A119 V3 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15297 Location: Bradford, West Yorkshire
Posted: Thu Dec 30, 2021 6:14 pm Post subject: |
Are you referring to the built in ones from Garmin or ones you have manually added? |
Posted: Thu Dec 30, 2021 8:38 pm Post subject: |
MaFt wrote: | Are you referring to the built in ones from Garmin or ones you have manually added? |
I manually added them some time ago. I'm now fed up with seeing knives and forks all over the screen. |
Posted: Fri Dec 31, 2021 6:16 am Post subject: |
Search the device for all .GPI files and post back what you find.
We can then compare notes as to what should and shouldn't be there as I've got no additional POI's.
No rush, I'm not back home till Sunday _________________ DashCam:
Viofo A119 V3 |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Fri Dec 31, 2021 7:27 am Post subject: |
Note Garmin will hoover up POI files from anywhere, not just in the POI folder, so do a global search for .gpi files. Having said that the issue appears to be that you have the Up ahead map layer checked, which is why you're seeing knives and forks etc everywhere. Uncheck it and they should disappear. _________________ Where there's a will ... there's a way. |
Posted: Fri Dec 31, 2021 10:09 am Post subject: |
Many thanks. I'll follow the advice given and report back. |
Posted: Fri Dec 31, 2021 3:46 pm Post subject: |
Found one .gpi file 1.33 mbyte. Deleted it and when I checked the POI file it was empty. I won't be out in the car until tomorrow so I'll have a look and see what's happened then. |
Posted: Sat Jan 01, 2022 11:43 am Post subject: |
Coaster2 wrote: | Found one .gpi file 1.33 mbyte. Deleted it and when I checked the POI file it was empty. I won't be out in the car until tomorrow so I'll have a look and see what's happened then. |
Unfortunately all it did was to get rid of all the speed cameras. When I use the POI loader to load the speed cameras I get the message: ‘Congratulations you have successfully loaded 17671 POIs on your device.’ |
Posted: Sat Jan 01, 2022 12:05 pm Post subject: |
On a PC you should be able to the creation date, plus the filename will be the POILoader folder name so you can identify that one easily. _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Jan 01, 2022 1:28 pm Post subject: |
I've tried everything now and the only way I seem to be able to get rid of the knives and forks is to lose the speed cameras as well. Looks like I'm going to have to live with it. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 754 Location: Knaresborough, North Yorkshire.
Posted: Sun Jan 02, 2022 12:03 am Post subject: |
You should listen to sussamb, I think.
On my Garmin 2599. I get icons for knives and forks (etc) on the screen from the (Foursquare) POIs which are effectively built into the map.
The way to hide them is as sussamb has said.
On my Garmin, I go into settings for Map & Vehicle ... Map Layers and uncheck Up Ahead and press Save.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
