Pocket GPS World :: View topic - End of Spec camera announcement, a camera too early!
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android
toyracer69
PostPosted: Tue Dec 07, 2021 11:44 pm    Post subject: End of Spec camera announcement, a camera too early! Reply with quote
Been using STA for a while (on a Huawei P30Pro) and have been updating the database weekly (manually), so when the auto update option became available I was over that like a rash. ;)
But on my route back from Clacton, that I do at least once a month, I noticed that the Penultimate spec camera on the A12 was being spoken as if it was the end of the average speed camera section. Where as there was one more camera to go. Also confirmed on my Sat Nav.
I thought it was a one off but last week I did a trial where I used the auto down loaded database for the first journey there. (It missed the last actual camera) and on the second journey I used the manual down loaded database. (Where it announced the cameras correctly!)
Any idea as to why this might be happening as they should be the same data and the cameras on my Sat Nav were also correct.....
Ta Pete
PostPosted: Wed Dec 08, 2021 5:56 am    Post subject: Reply with quote
If you can identify the camera(s) by number I'll have a look.
I found a similar one on the M4 that MaFt corrected. The start/middle/end need to be correctly tagged as STA uses a different system to ID the cameras.
toyracer69
PostPosted: Thu Dec 09, 2021 12:55 am    Post subject: Reply with quote
Will do....
toyracer69
PostPosted: Thu Dec 09, 2021 12:58 am    Post subject: Reply with quote
the cameras are ID: 172495 and ID: 172496
PostPosted: Thu Dec 09, 2021 6:22 am    Post subject: Reply with quote
Yes, that's the same issue as the M4 one.
Go into the submission map and change the type from just "Specs Average Speed" to the appropriate option of the 3 options below :
Specs, Start, Average Speed
Specs, Middle, Average Speed
Specs, End, Average Speed
That will/should be picked up for next Wednesday and accredited to you.
PostPosted: Thu Dec 09, 2021 8:38 pm    Post subject: Reply with quote
172495 needs to be MIDDLE from what I can tell.
172496 is already an END.
I think it's 172495 causing the issue. From memory if an average speed camera isn't marked as MIDDLE then STA assumes it is an END (as in most specs would be in pairs - 1st is start, 2nd is end)
If you submit that change it can be linked to you. Failing that I'll do it but you won't get any reward Wink
toyracer69
PostPosted: Thu Dec 09, 2021 10:47 pm    Post subject: Reply with quote
Submitted both, 'middle' for 172495 and 'end' for 172496.
plus I'm already a life time member. Cool
It was just strange that if I manually down loaded them it worked correctly but using the auto down load did not..... Question
Leo_A
PostPosted: Fri Dec 10, 2021 2:50 pm    Post subject: Reply with quote
SPECS without any attribute (mid, end, etc) stops current av. section.
PostPosted: Fri Dec 10, 2021 3:02 pm    Post subject: Reply with quote
Thanks for confirmation.
toyracer69
PostPosted: Tue Feb 15, 2022 9:28 pm    Post subject: Reply with quote
Just to let everyone know, it now works as it should. Via the auto upgrade option. Wink
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android All times are GMT + 1 Hour
22.113 (20 Nov 24)
