Kremmen Pocket GPS Verifier
Posted: Wed Jun 30, 2021 4:43 am Post subject: |
Be aware that many dashcams need at least 1.5A, some 2A, and many fag lighter USB plugs don't supply that amperage.
Plus the USB cable AWG rating needs to be suitable.
One poster on Dashcamtalk had a freezing dashcam until he changed his USB cable from 22 to 26 AWG. _________________ DashCam:
Viofo A119 V3 |
PaulWH Lifetime Member
Joined: Mar 27, 2006 Posts: 67 Location: West Kent, UK
Posted: Wed Jun 30, 2021 6:27 am Post subject: |
Thanks again for that info.
My Dashcam is a Vantrue N4 and has a USB "C" connection so hopefully I won't have an issue using a small 12v to USB "C" converter along with a quality cable. |
MichaelCahill Regular Visitor
Posted: Thu Jul 01, 2021 5:31 pm Post subject: |
I notice that there is a software update available, TrafficProvider.xml. Release notes state "Performance improvement for some locations"
Perhaps Garmin have increased the number of providers on Smartlink to compensate for the loss of Digital Traffic reception in the UK? |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Thu Jul 01, 2021 7:39 pm Post subject: |
MichaelCahill wrote: | I notice that there is a software update available, TrafficProvider.xml. Release notes state "Performance improvement for some locations"
Smartlink providers don't appear in TraficProvider.xml. Only Digital (DAB) and TMC (FM) providers appear in TraficProvider.xml. The Smartlink providers are contained within the phone app, so an updated phone app would be needed for additional Smartlink providers.
Prior to this update, for the UK, the TraficProvider.xml has Inrix and Trafficmaster as TMC (FM) providers and Inrix as the only Digital (DAB) provider.
Edit:
This update simply removes the Digital (DAB) provider for the UK, leaving only the two TMC (FM) providers. _________________ Paul |
Posted: Fri Jul 02, 2021 4:42 am Post subject: |
I did a quick test yesterday and my phone connected to both the car, for STA, and the Garmin for traffic.
See how it goes but there is no other solution as TT are phasing out their units with the SIM and the latest 2021 units all need a smartphone for traffic.
Roll on a car change later this year with Android Auto. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Jul 02, 2021 7:13 am Post subject: |
Well, so far so good .....
I tested Smartlink, or Smartphone Link as they now call it, on my 2599 a few months ago and it wasn't up to par.
However, having used it in anger this morning it correctly showed the M4 roadworks almost identical to what Inrix via the TA cable did.
It wouldn't surprise me if Garmin still use Inrix but now via your phone.
The only difference I noted was that I had an almost permanent "On Fastest Route" display that only previously appeared briefly. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Jul 02, 2021 5:21 pm Post subject: |
Snag, Smartphone link is eating the battery.
I've changed 'Location' permission from allow all the time to only when the app is active and the traffic still comes in OK.
I'll see how that reduces the drain. _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Jul 04, 2021 7:34 am Post subject: |
Yes, battery drain solved by changing Location Permission from Always to Only when Active. _________________ DashCam:
Viofo A119 V3 |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 564 Location: North Devon
Posted: Sun Jul 04, 2021 3:48 pm Post subject: |
Kremmen wrote: | Be aware that many dashcams need at least 1.5A, some 2A, and many fag lighter USB plugs don't supply that amperage.
I checked the current draw of a Nextbase 512GW, using my Brymen BM235 recording DMM.
Peak current was 315mA (possibly charging the super-capacitor in the Nextbase) - the average was approx. 52mA.
Quote: | Plus the USB cable AWG rating needs to be suitable.
One poster on Dashcamtalk had a freezing dashcam until he changed his USB cable from 22 to 26 AWG. |
(I assume that's a mis-quote, as 22AWG is thicker than 26AWG - though, not being American, I'm not overly familiar with this standard.)
Even assuming (the thinner) 26AWG, 315mA should only drop 244mV over a 10' length. (According to: https://www.rapidtables.com/calc/wire/voltage-drop-calculator.html).
There are however, many and various 12V car adaptors on the market. I shouldn't imagine many (if any) implement Garmin's 'ID resistor' based scheme and I'd be surprised if many implement the official 'USB Battery Charging Specification'.
Caveat emptor and all that!... |
Posted: Sun Jul 04, 2021 4:52 pm Post subject: |
Thanks P
There is a dedicated area on Dashcamtalk where Nextbase support operate. All the latest series 2 dashcams still have lithium batteries that Nextbase are receiving support posts about as they seem to have a short lifespan compared to caps.
It seems from the posts that their dashcams, especially the 522 for some reason , eat batteries in about 18 months for a lot of owners.
I also read regular posts where usb sockets and/or usb cables are replaced after advice and getting better quality with a higher max amperage solves problems, especially freezing.
It's like here where by regular visits you pick up useful info and tips and problems and solutions from others. _________________ DashCam:
Viofo A119 V3 |
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 494 Location: South Yorkshire
Posted: Sun Jul 18, 2021 9:09 pm Post subject: |
Yeh the batteries are rubbish in my 522GW has to be permanently connected to power even if wish to transfer a couple of files.
As for Garmin I no longer use mine and just use the TomTom app via Android Auto (found way to enable feature on my car and it works a dream). I also take my Go6200 as backup just incase |
Posted: Mon Jul 19, 2021 5:41 am Post subject: |
I'm hoping to change my car in the next few months and it will have Android Auto.
That will give me another method to test to see if I can avoid wiring in my DS61. _________________ DashCam:
Viofo A119 V3 |
INTRANET Occasional Visitor
Posted: Fri Oct 01, 2021 10:32 am Post subject: |
I did read whole thread and still not clear what is diff between SmartLink and Drive app? I'm using Drive app with DS65 MT-D. |
