redcar Occasional Visitor
Posted: Fri Jun 04, 2021 12:01 pm Post subject: Garmin Drive 51 |
Hi Guys.
I have purchased a Factory refund from what I thought was an official supplier with full EU LMT-S maps but 2019, however on updating via Express it now only has Central Europe 2021.30. Company are useless and aren’t helping and Garmin Tech U.K. won’t either as it’s a reseller.
What can I do I have had the unit 3 days. |
Kremmen Pocket GPS Verifier
Posted: Fri Jun 04, 2021 12:51 pm Post subject: |
When you identify the unit in Garmin Express there should be a 'Map Options' option.
In there should be the maps you can download. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Jun 04, 2021 1:04 pm Post subject: |
Hi. Yes it does and I use Exprss for my other devises, for some reason it has installed Central Europe only and deleted my Full EU maps, if I check options it is the same map. |
Posted: Fri Jun 04, 2021 2:38 pm Post subject: |
Check the free space on the unit. Sometimes reduced maps are installed when the full ones don't fit. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Jun 04, 2021 2:51 pm Post subject: |
Unit has 2gb spare and sd card has 16gb, it’s as if the update has deleted and just installed one, it makes my wonder if the maps were unlocked in the first place. The “authorised” reseller isn’t very responsive and speaking with Garmin tech they say they’ve had a few refurbs like this recently, every though it’s a factory refurb.
Looks like I’ll have to go down the return it route. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Sat Jun 05, 2021 7:32 am Post subject: |
Certainly shouldn't work like that. If the updated map region is installed you should then get the option to install the full map under Map Options in Express. You might try the cloning method to see if that works for you
http://www.poi-factory.com/node/39231 _________________ Where there's a will ... there's a way. |
Posted: Sat Jun 05, 2021 8:10 am Post subject: |
sussamb wrote: | Certainly shouldn't work like that. If the updated map region is installed you should then get the option to install the full map under Map Options in Express. You might try the cloning method to see if that works for you
http://www.poi-factory.com/node/39231 |
Thank you, will this work with a new Garmin Drive 51 LMT-S |
Posted: Sat Jun 05, 2021 5:05 pm Post subject: |
Yes, see the notes _________________ Where there's a will ... there's a way. |
Posted: Sat Jun 05, 2021 5:07 pm Post subject: |
sussamb wrote: | Yes, see the notes | 👍 |
