Pocket GPS World :: View topic - changing ov2 or csv files
lexuscol
PostPosted: Fri Oct 15, 2004 6:10 pm    Post subject: changing ov2 or csv files Reply with quote
Hi again, can anyone advise of a program/utility that will allow me to change poi ov2 files to work in copilot 5?
Tim Buxton
PostPosted: Fri Oct 15, 2004 6:31 pm    Post subject: Reply with quote
What format does CoPilot require?
Tim
MDRedwood
PostPosted: Fri Oct 15, 2004 6:43 pm    Post subject: Reply with quote
I think it is XLS, at least I hope it is as I am in the middle of generating some POI's for my new copy of CoPilot 5!
I found POIconverter 3.09 (the link to the home page is in the downloads section) works well; it converts just about any format of POI files to any other format. It works on my copy of XP SR2.
For importing them, I'm following the instructions for importing the "safety" camera POI's into CoPilot.
Good luck. Cheers,
Mike
MDRedwood
PostPosted: Fri Oct 15, 2004 6:57 pm    Post subject: Reply with quote
I've just dug out the website for POI converter, its writted by Richard Davies:
http://rjdavies.users.btopenworld.com/
Cheers,
Mike
lexuscol
PostPosted: Fri Oct 15, 2004 6:58 pm    Post subject: Reply with quote
Thanks I will have a look at that program. it is XLS format i believe as the safety camera's are imported by xls.
xda
PostPosted: Sat Oct 16, 2004 7:50 am    Post subject: Reply with quote
The Pocketgps camera download already has the .XLS files for CP in the archive.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
MDRedwood
PostPosted: Sat Oct 16, 2004 5:01 pm    Post subject: Reply with quote
Good point! Embarassed
I meant to say that I was also looking at converting/downloading other POI's written for TomTom in ov2.
Cheers,
Mike
xda
PostPosted: Sat Oct 16, 2004 10:31 pm    Post subject: Reply with quote
Cheers,
Mike
You can use any TT OV2 file, it's a two stage process. Using POIConverter, Click on File open, change type to TomTom OV2 and select from list of your OV2 files. POIConverter will then show imput from and the path to your selected OV2 file. Click File Save the save file screen comes up, change type to Autoroute.CSV and save.
Using Microsoft Exel open the CSV file then save it As Type .XLS
This XLS file can now be used in CoPilot.
Graham.
Nokia 925 Windows 8
MDRedwood
PostPosted: Sun Oct 17, 2004 12:49 am    Post subject: Reply with quote
Thanks Graham.
I'll do as you suggest.
Doesn't the direct conversion from ov2 to xls in POIconverter work for CoPilot?
Cheers,
Mike.
CoPilot 5 on Fujitsu Loox 720
stuartm
PostPosted: Sun Oct 17, 2004 9:45 am    Post subject: Reply with quote
CoPilot will quite happily import .csv files, do the import from excel but select the .csv instead of the .xls.
