Pocket GPS World :: View topic - Tom Tom Lockup
Tom Tom Lockup
barleymo
PostPosted: Thu Oct 14, 2004 11:17 am    Post subject: Tom Tom Lockup Reply with quote
Hi All,
I am having trouble with my tom tom locking up. I am running an IPAQ 2210 that runs Fungawi and TTN 3 with CheckPOInt. I use a Fortuna Clip-on BT Mouse. Origionaly I was having trouble getting Fungawi to talk to the Mouse, even when I installed the 2.07 BT Driver. Following some advice from a forum I installed the 3.03 driver and uninstalled it once so that it did not completely remove it. That appeared to cure the problem. However it would now appear that TTN drops out its connection to the GPS. THe BT is still active and the mapping works, you can put in a route and it calculates it, but the position in the navigator window sticks on the locked position and all I can do is a soft reset to get it working again. I have recently defragged the cards & formatted them Fat 32.
Any Ideas???
Software Installed:-
TTN 3 (Maps on SD card)
CheckPOInt 3.2 (8 POI db's on SD card)
BTregTweak (Stops it asking for BT device every time)
Fugawi 1 (Maps on CF)
barleymo
PostPosted: Mon Oct 18, 2004 9:54 am    Post subject: Found the answer Reply with quote
Managed to find the answer to this.
The system was running an early version of TTN 3. I upgraded the install to TTN 3.03 and it appears to have sorted the problem.
22.064 (26 Jun 24)
