jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Thu May 14, 2020 10:26 am Post subject: |
Thanks Kremmen for that.
I still wonder though if I did something silly. What would happen if I pressed the "Recover CSV Base files" before I unzipped the Database ?. The reason I ask is because it is dark green when the Direction Converter programme is started and all the colummns are blank. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
M8TJT The Other Tired Old Man
Posted: Thu May 14, 2020 11:18 am Post subject: |
Now you have it working properly, do one of two things.#
a. Put it down to a data glitch from PGPSW which it appears to be as Dales saw it too and forget all about it until (if) it happens again. (BY FAR THE BEST OPTION)
b. Try your suggestion above and report back.
c. I can't count. |
Posted: Thu May 14, 2020 11:24 am Post subject: |
I have just done B and all worked ok so I am now doing A
Have a good day _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Kremmen Pocket GPS Verifier
Posted: Thu May 14, 2020 11:44 am Post subject: |
At the moment I do have time to sort out any glitches.
The Direction Converter was specced out by Dales and I haven't had any bug reports for years on that so I leave well alone.
The CSV Converter also hasn't had any bug reports for ages but I am concious that there may be some Direction Converter to CSV Converter things/oddities that may well be there.
Anything Direction Converter related must go through Dales for analysis and final say so. _________________ DashCam:
Viofo A119 V3 |
Posted: Thu May 14, 2020 2:22 pm Post subject: |
But is seems that there is nothing wrong with either of them, unless you want to trap for every possible data error.  |
Posted: Thu May 14, 2020 3:31 pm Post subject: |
That was my thought, one incident isn't a problem. _________________ DashCam:
Viofo A119 V3 |
Posted: Thu May 14, 2020 3:43 pm Post subject: |
Unless MaFt makes a weekly habit of it to keep us on out toes. |
Posted: Fri May 15, 2020 2:15 pm Post subject: |
@jonial
Were you using the Direction Converter first or just the CSV Converter ? _________________ DashCam:
Viofo A119 V3 |
Posted: Fri May 15, 2020 2:18 pm Post subject: |
I was using the Direction Converter first then the the CSV converter.
I do have a copy of the rogue .csv files but dont know how to send them to you. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Fri May 15, 2020 3:37 pm Post subject: |
Thought so .... and I've reproduced the error.
Download database, unzip, process.
Unzip again and process.
If you keep unzipping and processing you can get multiple Latitude lines.
It's not deleting the existing CSV files on an unzip.
Program fixed and with M8 for QA.
This problem has been there since the year dot and is a coincidence that 2 of you have double unzipped and processed before going to the CSV Converter. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri May 15, 2020 4:17 pm Post subject: |
I did think it might be operator error but I have to say that managed to find a bug in the programme. It has certainly awakened my brain.
Thanks for your understanding and sorting of the problem.
Keep up the excellent work all of you.
Must pay my subs now !!! _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Fri May 15, 2020 6:27 pm Post subject: |
Good find, I did wonder how long it would take someone to find it  _________________ DashCam:
Viofo A119 V3 |
Posted: Fri May 15, 2020 10:19 pm Post subject: |
Took quite a while. Then like busses...........  |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 755 Location: Knaresborough, North Yorkshire.
Posted: Fri May 15, 2020 10:41 pm Post subject: |
Look M8 ...
... if the Krem (of the Krem)
wants me to break his program, then I will try and oblige !
... although it did take me a while to replicate jonial's procedure (I'm truly sorry for the delay).
Subsequently I did achieve an Error 13 out of the new version on first install, but I cannot now reproduce it (although not from lack of trying !).
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Sat May 16, 2020 5:44 am Post subject: |
During fault analysis, with M8 TeamViewer on my machine, I was able to produce files with 2,3,4 consecutive lists each with their own header and footer in each file.
The Direction Converter has to open and close each file and append to it as it works its way down the single long master csv file.
By not deleting any existing csv files at the start it was appending to existing completed files.
Once the CSV Converter got at them, it changed the csv files to gpx so no csv left.
What happens now is as soon as you unzip the new file(s) the display fields will turn white as the csv's are gone, temporarily.
In the bugged program the display fields were still green during the download and unzip as the csv's still existed. _________________ DashCam:
Viofo A119 V3 |
