Pocket GPS World :: View topic - Remove Duplicates Module error in Garmin CSV to GPX Converte
Goto page 1, 2, 3, 4  Next
jonial
PostPosted: Wed May 13, 2020 2:03 pm    Post subject: Remove Duplicates Module error in Garmin CSV to GPX Converte Reply with quote
I have run into a problem whilst trying to process the latest update.
The error message reads Conversion from string "latitude" to type "Double" is not valid. 13
I hope this is the proper place to ask for help please.
The programme has run perfectly for a long time
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Wed May 13, 2020 2:46 pm    Post subject: Reply with quote
Yep. Here's as good a place as any.
I'll have a go on mine in a bit and I expect the author Kremmen will be along before long.
OK. Just downloaded and process latest DB. No problem.
Base CSV cams = 14,930
Removed 1247
Processed 13,683
Total GPI cams 17,672
Presumably you have tried a fresh D/L and unzip?
jonial
PostPosted: Wed May 13, 2020 2:57 pm    Post subject: Reply with quote
I have tried fresh downloads and unzips still the same.
It is strange as nothing has changed on my PC
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
jonial
PostPosted: Wed May 13, 2020 3:10 pm    Post subject: Reply with quote
My apologies
I should have said that the files are unzipped in the CSV Direction Converter and they are processed in the Converter and then the failure occurs when trying to process them in the CSV to GPX Converter.
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Wed May 13, 2020 3:11 pm    Post subject: Reply with quote
I assume that you are using the program to download and unzip the PGPSW file are you.
I only ask, as some people unzip it 'by hand' rather than using the prog, and it don't work like that.
jonial
PostPosted: Wed May 13, 2020 3:36 pm    Post subject: Reply with quote
Yes downloaded and unzipped in the Direction converter.
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Wed May 13, 2020 4:12 pm    Post subject: Reply with quote
Very odd.
I had a trip to do yesterday (Tues) so I downloaded the latest and used the Converter without issue Mon evening.
That error is saying that it's found a file that still has the "Latitude" in the top line. Part of the Converter unzip routine is to remove that 'header' line.
Can you check you don't have any existing rogue CSV files.
2) Are you using your same location so we know it's read/write OK
3) As the Converter is running is shows progress, can you tell from that what file it's having issues with.
jonial
PostPosted: Wed May 13, 2020 4:25 pm    Post subject: Reply with quote
Hello Kremmen
How do I check for rogue files?
The problem occurs after I have clicked the Green Process button the Columns turn light green and the erro message appears.
Hope this helps
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
dales
PostPosted: Wed May 13, 2020 4:29 pm    Post subject: Reply with quote
It's doing it for me.
Each pmobile file (except an empty one) - its contents look to be doubled up, with a rogue line half way down - longitude latitude name.
Dales
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
PostPosted: Wed May 13, 2020 4:34 pm    Post subject: Reply with quote
Ah, thanks D
I don't download mobiles, hence why I didn't have the problem.
Is it a PGPSW rogue file problem ?
PostPosted: Wed May 13, 2020 4:36 pm    Post subject: Reply with quote
... and is it last weeks file or todays new one
jonial
PostPosted: Wed May 13, 2020 4:48 pm    Post subject: Reply with quote
The version that fails for me is dated06/05/2020.
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Wed May 13, 2020 4:54 pm    Post subject: Reply with quote
Hopefully corrected with today's update, later.
Surprised it's taken a week to spot, obviously, like me, haven't needed it
dales
PostPosted: Wed May 13, 2020 4:55 pm    Post subject: Reply with quote
It's the file for 6.5.20 (the latest the Converter can see).
The PGPSW file looks OK.
And I've just deleted all csv files in the Converter folder, rerun the programs, and all is working OK.
Very strange !
PostPosted: Wed May 13, 2020 4:59 pm    Post subject: Reply with quote
Not PGPSW, yes, very odd.
Got me beat
Page 1 of 4
22.123 (18 Dec 24)
