knightz Occasional Visitor
Posted: Sun Dec 15, 2019 7:25 pm Post subject: |
M8TJT wrote: | Are we in STA? I don't have
Settings - Text-to-speech
And I can only change the default language in
Settings - Audio settings - Speech synthesis.
And I can't find it in the phone settings either.
Found it.
Phone - settings- accessibility - screen reader - settings = text to speech-preferred engine.
Jeez how bleeding deep can the bury it. Now to test with STA
Ah, that's a bit better. |
Thanks |
M8TJT The Other Tired Old Man
Posted: Sun Dec 15, 2019 11:55 pm Post subject: |
Kremmen wrote: | I just went into settings then used the top magnifying glass search for 'text to speech' took me straight there. | That's because you are a smart ass clever dick. Why don't I think of silly things like that? Quote: | Be interested to see what you think of it in comparison to Sammy TTS. I'm using the default female voice #1 | Yep, that's the one I am using. I'm not clever enough to change is, unlike other smart asses that I know. But I agree, she sounds far less less roboty and the 'nicest' of those available.
Does it work OK with BT in your preferred configuration K? |
Kremmen Pocket GPS Verifier
Posted: Mon Dec 16, 2019 5:03 am Post subject: |
Works perfectly OK via BT and exactly the same as CA in that respect.
It automatically fires up when it detects a BT connection and shuts down when the connection is lost. Both the auto start and stop are individual options.
Given the Specs banner issue, pending a CA update or a MaFt bespoke database I'm going to disable the banners. Don't need them, just the announcement of cameras.
What I haven't tested yet is the overspeed warning as I don't exceed 50 in the roadworks.
Next trip probably Wednesday but definately Thurs.
The second set of Specs near Maidenhead I just lift off the go pedal so CA does give me a couple of warnings until cruise control has me down to Satnav 50, just in time for the first camera. I'll do the same and see what happens.
I'm expecting a series of beeps. What would be nice is an overspeed alert option using TTS so you can your own warning. _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Dec 16, 2019 9:31 am Post subject: |
The overspeed warning is a continuous series of beeps. Bit of a pain. I have raised this with Leo. |
Posted: Mon Dec 16, 2019 12:17 pm Post subject: |
He's cracked text to speech so he should be able to give us a free hand in what warning we want.
"Get that right foot off the loud pedal" (polite version) _________________ DashCam:
Viofo A119 V3 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15408 Location: Bradford, West Yorkshire
Posted: Mon Dec 16, 2019 1:35 pm Post subject: |
M8TJT wrote: | You are right about SPECS end. The information about start and end cameras is not in the PGPSW iGO database.
The popup is meant to be there all the time, or are you talking about the banner which can be dismissed with a double tap IIRC.
Presumably you have played with the various volume controls within the app K. |
iGO has always assumed that SPECS come in pairs and only pairs. They don't use START or END as such, the first SPECS you hit starts averaging, the second then ends it, the 3rd then starts it again. That's why the data isn't in the iGO format as iGO can't use it. |
Posted: Mon Dec 16, 2019 1:37 pm Post subject: |
Kremmen wrote: | For those now using Speedtrap Alert on a Samsung .... replace Samsung TTS with Google TTS. Text To Speech.
It produces a proper, not robotized, voice and is louder.
@MaFt, would it be feasible to produce a bespoke iGo based database with an additional column for start, middle and end Specs ? |
If you give me the specifications that the app needs then yes - I can. I can even call it 'Speedtrap' instead of iGO too to avoid confusion  |
Posted: Mon Dec 16, 2019 1:40 pm Post subject: |
Another app that I find useful is Velociraptor - it overlays the current road speed on your map/app. You can either use free data from Open Street Map or there are paid options to use TomTom's road speed data. |
Posted: Mon Dec 16, 2019 1:44 pm Post subject: |
I was hoping, subject to PGPSW being happy with a CA competitor, taking the current:
iGO [UK - Single file with all cameras]
and create a new database maybe:
SpeedTrap [UK - Single file with all cameras]
The only difference would be an extra column.
So Specs camera 202920 would change from:
-0.49636,51.49468,4,50,1,269
to:
-0.49636,51.49468,4,50,1,269,End
Other Specs cameras would be terminated with Start and/or Middle
I guess it doesn't have to be "End" but anything that can be picked up
(1,2,3) (S,M,E)
Whatever is easiest. _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Dec 16, 2019 1:52 pm Post subject: |
It's not really a competitor - CA is free. The access to the data would still be via a paid subscription - there's no difference to installing the database onto a Garmin or TomTom.
The only issue really is being able to submit new locations or verifications from a different app. |
Leo_A Regular Visitor
Posted: Mon Dec 16, 2019 1:56 pm Post subject: |
MaFt wrote: | Kremmen wrote: | For those now using Speedtrap Alert on a Samsung .... replace Samsung TTS with Google TTS. Text To Speech.
Hi, I'm a developer. It would be great.
Specification for first test is simple:
SPEC start and middle - type 100010 (instead of default 4)
SPEC end - type 100011 (instead of default 4)
That's all.
For first test it is enough just to generate the text file. I'll test it and if everything is ok, then to include it to download page. |
Posted: Mon Dec 16, 2019 2:18 pm Post subject: |
Ignore this as Leo_A is on the scene, so take his word as gospel. But perhaps the bit in bold would be good.
The only thing that SpeedTrapAlert needs as far as SPECS is concerned is a marker to indicate the last in a series. This could be done as Kremmen suggests by another column, or as you suggest that you might be creating a separate database similar to the iGO .txt one, then it could be just to change the camera type from 4 to (say) 6. It does not require Start and Mid info.
What the app does is start and display the average calculation at the first SPECS, then resets the calculation on each subsequent camera. This of course leaves the calculation 'hanging' when you pass the last in the sequence.
It would also be extremely useful to include our dummy end specs as another category to 'perfect' the SPECS experience by cancelling calculation when you turn out of a SPECS zone as I know Leo is scratching his head about what to do if you leave a sequence 'in the middle'.
The developer 'tinkers' with the database a bit when it's imported to STA to get it into the format his app uses.
His codes for SPECS is Start = 10010 and End is 100011. He also has code 10030 for "fake speed camera" (Our dummies?)
Posted: Mon Dec 16, 2019 2:20 pm Post subject: |
Hi Leo. Welcome to PGPSW foryms.
I think Kremmen and I have raised a bit of interest in STA here.
Thanks for the Time to cam mod in the beta. |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Mon Dec 16, 2019 2:41 pm Post subject: |
Hi Leo_A,
to the forum!
The ability to know END and Exit SPECS would be useful.
Could you speak with MaFt about allowing direct download of the database to your App, obviously handshaking with PGPSW security?
Could you also speak with MaFt about using the verifier database and also and K and M about adding tools for verifiers such as adding notes etc?
Finally, could you produce an iOS version?
Garmin Camper 770 LMT-D |
Posted: Mon Dec 16, 2019 2:46 pm Post subject: |
If this takes off then it will take the pressure off CA for those of us with Samsung phones either with or with the threat of Samsungs Android 10 (Q)
SpeedTrap has got lot's of potential and given we have been running CA and PND's for years with PGPSW data we have some experience to pass on. _________________ DashCam:
Viofo A119 V3 |
