Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Sat Dec 14, 2019 2:25 pm Post subject: |
I used it this morning. I just used the speedometer display, no map.
The first thing I noticed is the 'annoying' digitized voice that is fairly quiet even though I've got it on 100%. That's something for Trev to tell the developer, make the current 100% say 70% or lower so we can increase volume through the bluetooth link.
When I used CA on the return journey it blasted me out as I'd raised the car volume to compensate.
Another issue it had was when it announced 2 Specs cameras back to back, one on the main drag and the other on the sliproad, it failed to return the audio. Left the pseudo phone call open.
Also, when in a Specs zone the popup never goes away, maybe that's by design.
My journey to Reading covers 2 Specs zones. When I left the first zone the popup remained so it's not recognising our 202920 Specs as an end camera.
It's close but no cigar I prefer CA so I hope it gets fixed. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Sat Dec 14, 2019 4:46 pm Post subject: |
You are right about SPECS end. The information about start and end cameras is not in the PGPSW iGO database.
The popup is meant to be there all the time, or are you talking about the banner which can be dismissed with a double tap IIRC.
Presumably you have played with the various volume controls within the app K. |
Posted: Sat Dec 14, 2019 4:55 pm Post subject: |
Yes, the banner.
Snag, the phone is down by the handbrake so I don't want to take my eyes off the road to find and double tap the banner.
The answer is for the banner to auto disappear xx secs ala all the other camera types. Maybe a setting somewhere, there are so many. _________________ Satnav:
Car Average MPG :
Mordorf Regular Visitor
Posted: Sat Dec 14, 2019 5:14 pm Post subject: |
I stopped using bluetooth audio because it kept getting stuck. I now route the audio through the car speaker system via Android Auto and it works perfectly. |
Posted: Sat Dec 14, 2019 6:23 pm Post subject: |
My ageing Honda is good as gold with CA via BT as it hasn't got AA compatibility. This was the first time.
I'm sure I've seen a setting to avoid back to back Specs warnings _________________ Satnav:
Car Average MPG :
Posted: Sat Dec 14, 2019 7:03 pm Post subject: |
If you can't see the screen, why are you concerned with the banner?
I tghink the idea of the banner on SPECS is to give you a constant readout of your average, and an indication of how fast you can go to maintain your average (you can optionally limit that to the SPECS zone speed) |
Posted: Sat Dec 14, 2019 7:31 pm Post subject: |
The speedometer screen has all that info so I don't need the banner as well.
The phone is in peripheral view for a quick glance but not for guiding a finger safely to perform 2 taps.
I'll look closer at the settings but for the time being I'll stick with CA until it's given Samsungs Android 10
Having that permanent banner with the last Specs camera detail, 5 miles back, isn't ideal. I still think a banner timeout is preferable.
What a shame iGo can't accommodate Specs end ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ Satnav:
Car Average MPG :
Posted: Sun Dec 15, 2019 4:47 pm Post subject: |
For those now using Speedtrap Alert on a Samsung .... replace Samsung TTS with Google TTS. Text To Speech.
It produces a proper, not robotized, voice and is louder.
@MaFt, would it be feasible to produce a bespoke iGo based database with an additional column for start, middle and end Specs ? _________________ Satnav:
Car Average MPG :
Posted: Sun Dec 15, 2019 5:09 pm Post subject: |
Or even just end to switch it off. |
Posted: Sun Dec 15, 2019 5:27 pm Post subject: |
Kremmen wrote: | replace Samsung TTS with Google TTS. Text To Speech. | How do you do that K? I can't find it.
New STA thread needed methinks. |
Posted: Sun Dec 15, 2019 5:36 pm Post subject: |
Google TTS is downloaded from the playstore.
Then when downloaded you should get a popup to enable it.
Then, the difficult bit, took me a while to find it, is to set Google TTS as the default TTS.
The difference in the voice alerts is, in my opinion amazing in comparison. _________________ Satnav:
Car Average MPG :
Posted: Sun Dec 15, 2019 5:44 pm Post subject: |
I have it installed already, but can't find out how to swap to it from Samsung. |
Posted: Sun Dec 15, 2019 5:59 pm Post subject: |
Settings - Text-to-speech - Preferred engine
Click the Preferred engine text and not the cog wheel _________________ Satnav:
Car Average MPG :
Posted: Sun Dec 15, 2019 7:12 pm Post subject: |
Are we in STA? I don't have
And I can only change the default language in
Settings - Audio settings - Speech synthesis.
And I can't find it in the phone settings either.
Found it.
Phone - settings- accessibility - screen reader - settings = text to speech-preferred engine.
Jeez how bleeding deep can the bury it. Now to test with STA
Ah, that's a bit better.
Posted: Sun Dec 15, 2019 7:21 pm Post subject: |
I just went into settings then used the top magnifying glass search for 'text to speech' took me straight there.
There are a lot of settings in Pie that are now buried deeper than of old.
Be interested to see what you think of it in comparison to Sammy TTS. I'm using the default female voice #1 _________________ Satnav:
Car Average MPG :
