walberton Occasional Visitor
Posted: Tue Nov 12, 2019 5:23 pm Post subject: Installing speed camera POIs on a VW Passat |
I have a 2017 VW Passat which is fitted with Discovery Media (Generation 2). Data is supplied and updated via an SD card. I have been trying to download the speed camera file and then add this to the POIs that already exist in the inbuilt GPS system. Can anyone tell me which SatNav system I select on the drop down menu and what file format I need in order for the built in equipment to read the data from the SD card? Many thanks in anticipation. Martin |
Kremmen Pocket GPS Verifier
Posted: Tue Nov 12, 2019 5:40 pm Post subject: |
Does this VW system allow POI's with proximity warnings ?
Most inbuilt systems only support POI's as navigation points. _________________ Lets be careful out there ! |
Allan_whoops Frequent Visitor
Posted: Tue Nov 12, 2019 6:45 pm Post subject: |
Many thanks for the suggestion. I will explore the options you have put forward. |
Tom59 Lifetime Member
Joined: Aug 05, 2006 Posts: 407 Location: Alconbury - UK
Posted: Fri Nov 22, 2019 1:50 pm Post subject: |
I used the "Garmin POILoader [UK - Consolidated By Type (Gatso,Mobile,etc) | pMobiles: Yes | French: No | Swiss: No ]"
The cameras are downloaded OK, but you cannot get sound warnings. _________________ TT Go 720 (T)
Firmware 9.430. Map: Western Europe V 875.3613
TT iPhone app
V 1.23 Map: Western and Central Europe 2 GB V 965.7286
TT iOS Go Mobile
V 1.1 Map: Western Europe 965.7248 |
Posted: Fri Nov 22, 2019 7:06 pm Post subject: |
Thanks. I will look for that and give it a try |
