M8TJT The Other Tired Old Man
Posted: Mon Sep 09, 2019 3:12 pm Post subject: |
g0tch wrote: | If that answer was meant for me, it wasn't my question. | Sorry, misunderstood. But K's Quote: | So, I must assume that an image cannot be uploaded directly from PC to this site. One must upload to a cloud server first. Thanks for explanation. | Correct  |
cottonsocks Regular Visitor
Posted: Mon Sep 09, 2019 3:31 pm Post subject: |
M8TJT wrote: | cottonsocks wrote: | I removed the other brackets on Kremmen's instructions, . | He didn't tell you to remove square brackets, he told you to add square brackets at the start and end of his nearly complete link.  |
No, you're wrong. I originally had square brackets like this [img][/img] but if you look at Kremmen's example, it's like this img][/img, so I changed mine to match.
"Here is a Imgur link:
img]https://i.imgur.com/FqVB2Mm.jpg[/img
To get it to work, copy it and add a square bracket to the start and end. When you do it will look like: "
Notice also that it says add "a" (meaning one) square bracket. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Mon Sep 09, 2019 4:03 pm Post subject: |
Yes, he was giving you a link to amend by adding the brackets otherwise you wouldn't have seen the link, it would have been a photo  _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 09, 2019 4:39 pm Post subject: |
sussamb wrote: | Yes, he was giving you a link to amend by adding the brackets otherwise you wouldn't have seen the link, it would have been a photo  | But I already had the brackets in my original post, so that wouldn't make any sense.
It still doesn't work anyway, at least, not for my links. |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 564 Location: North Devon
Posted: Mon Sep 09, 2019 4:44 pm Post subject: |
I tried to 'correct' the link to the box.com images in my first reply.
It didn't work - presumably because the hyperlinks don't refer to the actual JPEGs; they refer to a web page that then displays the JPEGs...
The link to the JPEG itself appears to be generated dynamically, so you can't capture it and use it bypass their interface  |
Posted: Mon Sep 09, 2019 4:53 pm Post subject: |
PhilHornby wrote: | I tried to 'correct' the link to the box.com images in my first reply.
I've removed the [img] parts, so at least it now displays active links, even if the photographs can't be displayed in the body text. |
g0tch Regular Visitor
Joined: May 15, 2008 Posts: 115 Location: North Somerset
Posted: Mon Sep 09, 2019 5:17 pm Post subject: Re: A few questions about the new devices |
Going back to your original query ...
cottonsocks wrote: | ... whether the latest models have solved the problem of being directed down single-[dirt]track country lanes... |
I would expect that one of 'truck' orientated units would go someway towards implementing that. If you tell it your car is 8' wide, you'd like to think it would keep you off 6'6" wide lanes
Units such as the Dēzl 580, are what I'm thinking of - though I have no experience of them: https://buy.garmin.com/en-GB/GB/p/589643
(If my Zūmo experience is anything to go by, you might still be sent down "Motor Vehicles Prohibited" roads though
I've reported my encounters to Garmin as mapping errors - I can't see any reason for such roads to be present in the map)
Posted: Mon Sep 09, 2019 6:59 pm Post subject: |
Then I suspect that it is the host stopping embedding pics.
@cottonsocks.
I am not wrong.
Kremmen told you to add a square bracket at the start [and the end of his the link (That's a total of two) and it will then show the pic.
But that besides, see my reply to g0tch above for a possible explanation. |
Posted: Mon Sep 09, 2019 7:25 pm Post subject: |
M8TJT wrote: | @cottonsocks And please remove the totally unnecessary quote of the post with the pic. |
Which post is that then? I wasn't aware I had quoted any posts containing a picture. |
Posted: Mon Sep 09, 2019 7:32 pm Post subject: |
M8TJT wrote: | Then I suspect that it is the host stopping embedding pics.
@cottonsocks.
I am not wrong.
Why would I have wanted to add two brackets to Kremmen's link, just to replicate what I had originally done with my own link and which hadn't worked? Also, since there were two brackets in Kremmen's link then I assumed his instructions were referring to what he had already done and the link was just reinforcing his instructions. That's why I removed two of my original brackets. But it's just academic now as it hasn't worked anyway, so I'm not going to spend any more time arguing about trivial matters like this. |
marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Mon Sep 09, 2019 8:11 pm Post subject: |
This is what they were saying about embedding the image. If you look at the difference between my post and the one Kremmen showed you how to do it, you will see the difference (notice the file extension).
Code: | [img]https://i.imgur.com/FqVB2Mm.jpg[/img] |
The link you have provided g0tch, doesn't appear to be a valid image file, so it won't display in the image brackets as it is a link to a html page. I don't know about appbox, but if you log in to your member area, it may give you options to share in BB code or similar.
Mark _________________ Garmin Drivesmart 51 LMT-D Europe |
Posted: Mon Sep 09, 2019 11:17 pm Post subject: |
cottonsocks wrote: | M8TJT wrote: | @cottonsocks And please remove the totally unnecessary quote of the post with the pic. |
Which post is that then? I wasn't aware I had quoted any posts containing a picture. | Page 2, your fifth post has a copy of the pic that Kremmen posted and I tested (and have subsequently deleted as being pointless and just further cluttering up the thread.).
Kremmen Pocket GPS Verifier
Posted: Tue Sep 10, 2019 4:37 am Post subject: |
Look what I started trying to be helpful.
If you're current picture host doesn't like being a picture host then use the free Imgur just for embedding pictures. _________________ DashCam:
Viofo A119 V3 |
