rabbitseggs Occasional Visitor
Posted: Sat Aug 03, 2019 11:02 am Post subject: Garmin Drive Smart 61 LMT-D |
Hi I am having problems with my Garmin Drive Smart 61 LMT-D. I want to remove pocketgpsworld camera alert. I have tried using POI Loader which tells me that I have successfully removed all POI. Indeed it does remove all POis except pocketgpsworld. If i go back into Custom POis all the camera alerts are still there.It would not be so bad but they do not work at all. No alert no icon even with red light. I have even tried a factory reset but they are still there. I just want to remove them and then reinstall so hopefully they will then work. Has anyone got a suggestion on how to solve this problem? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Sat Aug 03, 2019 12:10 pm Post subject: |
Just delete the .gpi file in the POI folder on the device. If it's not there search for *.gpi and you'll find it. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Sat Aug 03, 2019 12:32 pm Post subject: |
Strange that POIloader 'remove' hasn't actually removed all the .GPI files. _________________ Lets be careful out there ! |
Posted: Sat Aug 03, 2019 2:25 pm Post subject: |
Generally if for some reason the .gpi file isn't in the POI folder  _________________ Where there's a will ... there's a way. |
Posted: Sat Aug 03, 2019 3:11 pm Post subject: |
I did consider that but would the cameras still be found and display warnings if the GPI was somewhere else ? _________________ Lets be careful out there ! |
Posted: Sat Aug 03, 2019 3:28 pm Post subject: |
Yes, Garmins will hoover them up from other folders ;) _________________ Where there's a will ... there's a way. |
Posted: Sat Aug 03, 2019 3:38 pm Post subject: |
Didn't know that _________________ Lets be careful out there ! |
M8TJT The Other Tired Old Man
Posted: Sat Aug 03, 2019 3:54 pm Post subject: Re: Garmin Drive Smart 61 LMT-D |
rabbitseggs wrote: | ... all the camera alerts are still there.It would not be so bad but they do not work at all. | Would it not be better to get them working properly rather than removing them? |
Posted: Sat Aug 03, 2019 4:06 pm Post subject: |
If they're not working though probably best to start again as you can't edit a .gpi file _________________ Where there's a will ... there's a way. |
Posted: Sat Aug 03, 2019 4:26 pm Post subject: |
I agree, but if OP generates a new one with the same name, it will overwrite the ones that are not working. |
Posted: Sat Aug 03, 2019 5:28 pm Post subject: |
Yep, remove the .GPI database manually, via a PC connection, then follow the spoon feed version to get them back properly.
If the GPI isn't in the correct POI folder then how did it get wherever it is ? _________________ Lets be careful out there ! |
Posted: Sat Aug 03, 2019 5:58 pm Post subject: |
Who knows
I create mine on my PC then send them manually to my devices, maybe the OP did the same  _________________ Where there's a will ... there's a way. |
Posted: Sat Aug 03, 2019 7:52 pm Post subject: Garmin Drive Smart 61 LMT-D |
Thanks for your comments. As I said I did a factory reset and the pocketgpsworld were still showing in Custom POI. I looked in the internal storage via my PC and opened POI. The ars 9 GPI Cyclops Sample files relating to various European countries and 2 DNl files and 2 GMA files. No GPI files! I am convinced that it is these files that are stopping PocketGPSWorld working so any other ideas on how to delete them would be very welcome. |
Posted: Sat Aug 03, 2019 8:57 pm Post subject: |
A factory reset won't delete .gpi files but I'm now confused.
The Cyclops files won't stop the PGPSW files from working, but they can easily be deleted, just delete them using Windows Explorer. They should though have been removed via poi loader.
I suspect it's those cameras you were seeing if, as you say, there are no other .gpi files anywhere else on your device or any installed card. _________________ Where there's a will ... there's a way. |
Posted: Sat Aug 03, 2019 9:32 pm Post subject: Garmin Drive Smart 61 LMT-D |
If I go into Custom POI under the heading "All Categories" on the devise I see Pocketgps_uk_gatso_20
Pocketgps_uk_gatso_30
and so on until
Pocketgps_uk_specs_var
The complete list
There are the only POIs visible. |
