Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 56, 57, 58 ... 73, 74, 75  Next
g0tch
PostPosted: Thu Nov 01, 2018 4:17 pm    Post subject: Reply with quote
Kremmen wrote:
Ah yes, the Garmin POIloader directory rename change
Uninstall the old one and reinstall the latest one. It's quite painless and can be completed in seconds.
Many thanks for putting up with me. All done bar testing next time I need it. Will report if I find the size too big.
Thanks again
Tibor
Garmin Drivesmart 61
PostPosted: Thu Nov 01, 2018 5:34 pm    Post subject: Reply with quote
No problem this end. Smile
PostPosted: Sun Nov 11, 2018 1:08 pm    Post subject: Reply with quote
Small utility addition.
Something that can be easily overlooked is the amount of space Garmin Map and Firmware downloads take up.
I nearly got caught out when I had a smaller 120Gb SSD.
Just click the new Menu item and it should display rounded sizes:
Hope it's useful.
Usual download link:
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=1
I'll polish the display in the week.
PostPosted: Mon Nov 12, 2018 9:16 am    Post subject: Reply with quote
Polishing complete, updated version (same ID - 2018.11.11.73) is now:
Allan_whoops
PostPosted: Mon Nov 12, 2018 9:32 am    Post subject: Reply with quote
It may be worth listing all the downloaded map temporary files if that isn't already being done. That is what takes up the space after a map update. The other one is Basecamp temporary files which don't seem to be deleted.
PostPosted: Mon Nov 12, 2018 10:04 am    Post subject: Reply with quote
Thanks.
Have you got the Basecamp location as I haven't got Basecamp ? All I've got in my Garmin location is Application and Temp that I haven't linked to and my temp is empty.
I've had other feedback so there will be an update later today.
Allan_whoops
PostPosted: Mon Nov 12, 2018 10:16 am    Post subject: Reply with quote
Basecamp is
C:\Users\Fred\AppData\Local\Garmin\BaseCamp\TileCache
Mapsource is
C:\Users\Fred\AppData\Roaming\Garmin\MapSource\TileCache
PostPosted: Mon Nov 12, 2018 11:19 am    Post subject: Reply with quote
Ah, that's a variable directory.
*/Fred/* (or whatever) will be specific to the logged on username at time of download.
I'm sure I can trap the currently logged on user but that may not be where all those files are if the PC has more than on user.
Edit: Have you installed Basecamp for just you or all users ?
PostPosted: Mon Nov 12, 2018 12:11 pm    Post subject: Reply with quote
Latest, based on feedback:
Same link
Allan_whoops
PostPosted: Mon Nov 12, 2018 12:21 pm    Post subject: Reply with quote
Sorry, just seen this. I am the sole user so just me.
PostPosted: Mon Nov 12, 2018 12:33 pm    Post subject: Reply with quote
Is this across the board though for every installation ?
Anyone else got Basecamp and/or Mapsource to confirm their data location ?
Allan_whoops
PostPosted: Mon Nov 12, 2018 12:38 pm    Post subject: Reply with quote
Not sure - if installing on a system with more than 1 user and doing it individually, then probably.
PostPosted: Mon Nov 12, 2018 2:10 pm    Post subject: Reply with quote
I want it to be robust so confirmation of some others locations would be useful.
PostPosted: Mon Nov 12, 2018 2:49 pm    Post subject: Reply with quote
Also varies depending on the OS. Unsure how you could cope with all the variants?
PostPosted: Mon Nov 12, 2018 3:24 pm    Post subject: Reply with quote
So Basecamp and Mapsource data could be in a multitude of places.
I've still got another change to make as the temp field isn't wide enough when the GarminExpress stuff is in there. I'm going to trim off the time from all fields as what's there already is a screenful so no room to expand. Won't be for a few days though.
Page 57 of 75
