fozzie63 Occasional Visitor
Joined: Sep 26, 2004 Posts: 41 Location: Chichester, West Sussex, UK
Posted: Thu Oct 07, 2004 9:39 pm Post subject: |
I've got exactly the same with two on my way to work! |
jackofall Occasional Visitor
Posted: Fri Oct 08, 2004 7:20 am Post subject: |
I have also had the lockup and POI issues I emailed ALK 3 days ago and still no reply
Venompeter Occasional Visitor
Posted: Mon Oct 11, 2004 12:54 pm Post subject: |
stuartm wrote: | Venompeter wrote: |
Alert!
Alloc 356.60kb, ProgM 412 Kb, StrgM 911.88kb
I think the important bit is the title of the dialog, something like 'GB_MinApp::AddRoute' |
Yes, I do get that one too
Peter |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Oct 14, 2004 1:43 pm Post subject: |
I get the memory errors quite a bit. CoPilot seems to use up about 8 Meg of the phone memory. I find this bizzare since Mapopolis only uses about 300k Can anyone explain this? |
Posted: Thu Oct 14, 2004 1:48 pm Post subject: |
Skippy wrote: | I get the memory errors quite a bit. CoPilot seems to use up about 8 Meg of the phone memory. I find this bizzare since Mapopolis only uses about 300k Can anyone explain this? |
Sorry, forgot to mention that this is the Smartphone version. _________________ Gone fishing! |
stuartm Lifetime Member
Joined: 21/03/2003 10:37:20 Posts: 116 Location: Barkham
Posted: Thu Oct 14, 2004 3:14 pm Post subject: |
It might be useful to know the content of the error messages you get Skippy. |
Posted: Thu Oct 14, 2004 4:53 pm Post subject: |
stuartm wrote: | It might be useful to know the content of the error messages you get Skippy. |
I try to create a route from London to Dublin and I get a message:
GetCGD: Insufficient mem
Alert
Alloc: 111.77KB, ProgM:
132.00KB, StrgM: 926.75KB
You press the OK softkey and then CoPilot quits.
It's not just creating long routes that causes this error, it happens from time to time while doing other things too. _________________ Gone fishing! |
Posted: Fri Oct 15, 2004 9:15 am Post subject: |
Just driving along
GP_MinPath::AddOrigin
Alert
Alloc: 556.64KB
ProgM: 684.00KB
StrgM: 926.20KB |
Posted: Fri Oct 15, 2004 2:16 pm Post subject: |
If you are moving at less that 5 mph then the map doesn't update.
POIs disappearing has been mentioned, but I will mention it again, why on earth does that happen? I need to be able to see the POIs when I am moving.
CoPilot uses too much memory, ~8 Mb when running and has lots of out of memory errors.
Routing can be odd. Plot a route from London to Dublin (on the PC) and it takes you via the Stranraer-Belfast ferry (definately not the shortest or fastest route by a long way). If I set a via point at Holyhead then it routes me via the Holyhead-Dun Laoghaire ferry which is the more logical route.
Address lookup is painful. I enter an address in Dublin, IE and it gives me an error "Too many city matches. Please be more specific". Last time I checked, there was only one city called "Dublin" in Ireland. If you enter the city as "Dublin 1" then the lookup works fine and finds addresses in any Dublin postcode, not just " Dublin 1".
The "Take the next left" voice prompt needs to give more warning before the turn (the longest you can make it is 8 seconds). It is not too bad when you were given a warning at 3/10ths of a mile, but if the last turn was less than 3/10ths away then you are only told of the next turn when you are 8 seconds (or less) from the corner. This is not enough warning if you are in the wrong lane. _________________ Gone fishing! |
Posted: Fri Oct 15, 2004 2:17 pm Post subject: |
The coastline of the country disappears when you zoom out too. _________________ Gone fishing! |
Posted: Fri Oct 15, 2004 3:53 pm Post subject: |
Skippy wrote: |
According to the tech support people at ALK it is meant to work that way to avoid distracting the driver, personally I'd rather see them, I'd also like to be able to change the POI warning to less than 0.2 of a mile. |
Posted: Sat Oct 16, 2004 12:09 pm Post subject: |
stuartm wrote: | Skippy wrote: |
So it doesn't occur to them that the software may be used by a passenger then? _________________ Gone fishing! |
Posted: Tue Oct 19, 2004 11:32 am Post subject: |
Does anyone else have Custom Display in safety view set to Speed? Mine changes at random to other settings, this morning it changed to ETA. |
Posted: Tue Oct 19, 2004 11:58 am Post subject: |
Posted: Tue Oct 19, 2004 12:23 pm Post subject: |
Enter a single character for the "Town or Postal Code" when doing an address lookup and you get an error message "No Response From Server" _________________ Gone fishing! |
