Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 53, 54, 55 ... 73, 74, 75  Next
PostPosted: Fri Feb 23, 2018 10:24 am    Post subject: Reply with quote
It sounds like you are trying to re-run the installer rather than the program itself?
PostPosted: Fri Feb 23, 2018 1:01 pm    Post subject: Reply with quote
Microsoft ClickOnce insists that you manually uninstall any existing version first.
If it isn't in add/remove programs then search for /apps/ under your username and manually delete the whole folder. Do a C:/ search for 'converter.exe' to track it down.
It's already covered, with the acthal folder names here somewhere ......
turbo10
PostPosted: Fri Feb 23, 2018 1:53 pm    Post subject: Reply with quote
From the downloaded zip I have tried "setup.exe" and I get the message and tried "converter.application" same message, I must be missing something here Crying or Very sad
Triumph Tiger 800 XRt
Garmin Zumo 595LM
TomTom Live Truck
Samsung Galaxy S7 Edge
PostPosted: Fri Feb 23, 2018 2:16 pm    Post subject: Reply with quote
Does the converter show in your 'Add/remove Programs'?
You cannot re-install it without un-installing first, otherwise you get the error message that you have.
So either it is already installed or if you are trying to run the setup.exe a second time, that's what's wrong. You are not trying to run the program, but trying to reinstall it.
Once it has/is installed, you should have a shortcut on your desktop with a black camera icon. That's the one you need to run.
turbo10
PostPosted: Fri Feb 23, 2018 2:22 pm    Post subject: Reply with quote
It would seem it installed but I thought it hadn't because of no black icon on my desktop.
Checked add/remove progs and it was listed, removed it and reinstalled now it is working fine.
Thanks for your help
Garmin Zumo 595LM
TomTom Live Truck
PostPosted: Fri Feb 23, 2018 5:33 pm    Post subject: Reply with quote
No prob. Glad you've got it sorted. Post again in any other probs.
MIKECURTIS
PostPosted: Wed May 02, 2018 1:53 am    Post subject: Reply with quote
Is there any chance of getting the .gpi output file. I as too old (70) to cope with this nowdays!
PostPosted: Wed May 02, 2018 5:40 am    Post subject: Reply with quote
The GPI file is copyright to PGPSW even though it's a byproduct of the original database file. Nobody is allowed to distribute any part of the database in any format.
As a further disincentive each download is watermarked to each member so distribution origin can be detected.
Using my Converter is fairly easy and has been tweaked over the years based on feedback to make it as user friendly as possible.
Once you download the package read one of the help files.
PostPosted: Wed May 02, 2018 8:05 am    Post subject: Reply with quote
But you still need to convert the gpx it creates to gpi using POILoader K.
@MIKECURTIS. What device do you have Mike?
I'm 77 and can handle it OK.
g0tch
PostPosted: Tue Jun 05, 2018 12:01 pm    Post subject: Reply with quote
I’m about to install the latest version. Can you please refresh my memory about the following:
Do I need to delete the existing C:\Users\[username]\appdata\local\Apps\2.0\ file before I install new version?
Assume I can leave everything as is in the PGPSW folder?
Many thanks
Tibor
Garmin Drivesmart 61
PostPosted: Tue Jun 05, 2018 4:15 pm    Post subject: Reply with quote
No. Just uninstall the converter via "Programs and features" or whatever Microsoft call it on your flavour of Windows.
PostPosted: Tue Jun 05, 2018 5:08 pm    Post subject: Reply with quote
On Win7 it's 'uninstall a program'.
PostPosted: Wed Jun 06, 2018 8:55 am    Post subject: Reply with quote
On W10 it depends on whether you go into Control Panel or PC Settings.
'Apps' in PC Settings
'Programs and Features' in Control Panel.
Why didn't MS standardise rather than keeping on chopping and changing names.
g0tch
PostPosted: Wed Jun 06, 2018 10:10 am    Post subject: Reply with quote
Many thanks for replies, have my own uninstaller so will use that. It's windows 10.
Best regards,
Tibor
marksfish
PostPosted: Sat Jul 14, 2018 11:38 am    Post subject: Reply with quote
Struggling to get this installed on my Win 10 laptop. I have run the setup programme and set my preferred folder. If I download the database and unzip, I am told the image and voice files are missing, which is fine as I usually unzip to a folder and change names before moving to my POI folder. The programme is telling me they files have been unzipped, but they are not being put in my specified working folder. If I then try to open POI loader using the button provided, I get an "unhandled exception has occurred in your application" error.
I can't keep jumping between pc's to upload cameras, any ideas please?
Page 54 of 75
23.053 (21 May 25)
