M8TJT The Other Tired Old Man
Posted: Fri Feb 23, 2018 10:24 am Post subject: |
It sounds like you are trying to re-run the installer rather than the program itself? |
Kremmen Pocket GPS Verifier
Posted: Fri Feb 23, 2018 1:01 pm Post subject: |
Microsoft ClickOnce insists that you manually uninstall any existing version first.
If it isn't in add/remove programs then search for /apps/ under your username and manually delete the whole folder. Do a C:/ search for 'converter.exe' to track it down.
It's already covered, with the acthal folder names here somewhere ...... _________________ DashCam:
Viofo A119 V3 |
turbo10 Regular Visitor
Posted: Fri Feb 23, 2018 1:53 pm Post subject: |
M8TJT wrote: | It sounds like you are trying to re-run the installer rather than the program itself? |
From the downloaded zip I have tried "setup.exe" and I get the message and tried "converter.application" same message, I must be missing something here  _________________ Triumph Tiger 800 XRt
Garmin Zumo 595LM
TomTom Live Truck
Samsung Galaxy S7 Edge |
Posted: Fri Feb 23, 2018 2:16 pm Post subject: |
Does the converter show in your 'Add/remove Programs'?
You cannot re-install it without un-installing first, otherwise you get the error message that you have.
So either it is already installed or if you are trying to run the setup.exe a second time, that's what's wrong. You are not trying to run the program, but trying to reinstall it.
Once it has/is installed, you should have a shortcut on your desktop with a black camera icon. That's the one you need to run. |
Posted: Fri Feb 23, 2018 2:22 pm Post subject: |
It would seem it installed but I thought it hadn't because of no black icon on my desktop.
Checked add/remove progs and it was listed, removed it and reinstalled now it is working fine.
Thanks for your help _________________ Triumph Tiger 800 XRt
Garmin Zumo 595LM
TomTom Live Truck
Posted: Fri Feb 23, 2018 5:33 pm Post subject: |
No prob. Glad you've got it sorted. Post again in any other probs. |
MIKECURTIS Occasional Visitor
Posted: Wed May 02, 2018 1:53 am Post subject: |
Is there any chance of getting the .gpi output file. I as too old (70) to cope with this nowdays! |
Posted: Wed May 02, 2018 5:40 am Post subject: |
The GPI file is copyright to PGPSW even though it's a byproduct of the original database file. Nobody is allowed to distribute any part of the database in any format.
As a further disincentive each download is watermarked to each member so distribution origin can be detected.
Using my Converter is fairly easy and has been tweaked over the years based on feedback to make it as user friendly as possible.
Once you download the package read one of the help files. _________________ DashCam:
Viofo A119 V3 |
Posted: Wed May 02, 2018 8:05 am Post subject: |
But you still need to convert the gpx it creates to gpi using POILoader K.
@MIKECURTIS. What device do you have Mike?
I'm 77 and can handle it OK. |
g0tch Regular Visitor
Joined: May 15, 2008 Posts: 115 Location: North Somerset
Posted: Tue Jun 05, 2018 12:01 pm Post subject: |
I’m about to install the latest version. Can you please refresh my memory about the following:
Do I need to delete the existing C:\Users\[username]\appdata\local\Apps\2.0\ file before I install new version?
Assume I can leave everything as is in the PGPSW folder?
Many thanks _________________ Tibor
Garmin Drivesmart 61 |
Posted: Tue Jun 05, 2018 4:15 pm Post subject: |
No. Just uninstall the converter via "Programs and features" or whatever Microsoft call it on your flavour of Windows. |
Posted: Tue Jun 05, 2018 5:08 pm Post subject: |
On Win7 it's 'uninstall a program'. _________________ DashCam:
Viofo A119 V3 |
Posted: Wed Jun 06, 2018 8:55 am Post subject: |
On W10 it depends on whether you go into Control Panel or PC Settings.
'Apps' in PC Settings
'Programs and Features' in Control Panel.
Why didn't MS standardise rather than keeping on chopping and changing names. |
Posted: Wed Jun 06, 2018 10:10 am Post subject: |
M8TJT wrote: | On W10 it depends on whether you go into Control Panel or PC Settings.
Many thanks for replies, have my own uninstaller so will use that. It's windows 10.
Best regards, _________________ Tibor
marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Sat Jul 14, 2018 11:38 am Post subject: |
Struggling to get this installed on my Win 10 laptop. I have run the setup programme and set my preferred folder. If I download the database and unzip, I am told the image and voice files are missing, which is fine as I usually unzip to a folder and change names before moving to my POI folder. The programme is telling me they files have been unzipped, but they are not being put in my specified working folder. If I then try to open POI loader using the button provided, I get an "unhandled exception has occurred in your application" error.
I can't keep jumping between pc's to upload cameras, any ideas please? _________________ Garmin Drivesmart 51 LMT-D Europe |
