Pocket GPS World :: View topic - Nissan Connect 2 - various questions, sorry !
geejay38
PostPosted: Wed Oct 11, 2017 8:17 am    Post subject: Nissan Connect Reply with quote
I’ve now been told by Nissan to use a different download procedure so will try it later this week and report back.
However, can somebody confirm how they manage to get details of types of cameras shown on Connect3 screen, i.e. a screen width banner with warning text contained therein?
Nissan Connect System user
Garmin Dash Cam 45
Bigcol22
PostPosted: Tue Mar 06, 2018 11:37 pm    Post subject: Can’t see cameras Reply with quote
I have downloaded the camera datbase, followed the instruction on how to download and install onto the Nissan Connect, installed the file on the USB stick, installed into car, file in correct place, but it show nothing when I drive past know mobile camera’s, haven’t tried fixed camera’s yet.
I have checked that the file is loaded into the correct place and everything looks great, but still se nothing on my screen nor bleeps ... very frustration, anyone shine some light on this as I see very little input from Nissan Connect drivers on this site
geejay38
PostPosted: Wed Mar 07, 2018 10:41 am    Post subject: Nissan Comnect 2 Reply with quote
I agree there is not a lot of recent activity here but there has been in the past, particularly after I joined Forum!
Initially I had a problem downloading the speed camera data on my QQ.
This was because I did not extract the data from the database correctly.
When you connected the USB stick did screen show something like no audio files and then asked you if you wanted to replace existing POI files?
My Connect 2 System gave a ping when approaching mobile/fixed camera locations, a small camera sign on road location and box in bottom RH corner of screen.
To get warnings, type of camera and speed limits I had to download Database onto my mobile phone. Not ideal but useful if camera is SPECS variety
Hope that helps.
Garmin Dash Cam 45
Bigcol22
PostPosted: Thu Mar 08, 2018 12:29 pm    Post subject: Reply with quote
As previous, I have followed instructions to the letter, the speed camera data base is and has been downloaded onto the Nissan Connect.
Navigation,destination,points of interest,my points of interest,mypoiwarning,pocketgps.uk.sc, I can even call up cameras that are near my house and the Sat/Nav will Direct me to it, but will not show it on the screen, I currently use my IPhone as it’s more reliable, but would still like it on my Nissan Connect
geejay38
PostPosted: Thu Mar 08, 2018 1:00 pm    Post subject: Reply with quote
Well your in the same position as me then.
I have asked other Connect users the same question and the answer is always the same. Just a bleep and box on screen.
I use my iPhone to get rest of data.
Sorry cannot be of more help.
Garmin Dash Cam 45
Bigcol22
PostPosted: Thu Mar 08, 2018 3:40 pm    Post subject: Reply with quote
At least your getting something, I get nothing, not even a bleep 🤷‍♂️
Saltire_
PostPosted: Thu Mar 15, 2018 5:17 pm    Post subject: Reply with quote
Stupid question but I'll ask anyway, have you turned the 'on and beep' option to on in the 'my poi's' menu?
I have been using the database since I installed it on my 2014 X-trail and all it shows is a camera icon on the road and a camera icon in the bottom corner with distance, but it did show all the different types of camera but just used the same icon.
I have just bought the new facelift X-trail and hoped that they had improved the system but alas no, still the same icons. It's not the databases fault it's the connect system software.
I also dislike the fact that it tells me of cameras in a radius to me that are not even on the road that I am driving on, nor does it distinguish my direction an tells me of cameras that are on the oposite carriageway that dosen;t affect me.
Bigcol22
PostPosted: Fri Mar 16, 2018 11:32 pm    Post subject: Download Reply with quote
Hi all
Finally downloaded the speed camera data base ion the Nissan Connect, the secret is that one should always follow the instruction as printed.
I thought I had, but alas I didn’t check the I had put the correct name into the folder, always check, and double check that you have Upper and lower case when you make up your folders on your memory stick.
PostPosted: Sat Mar 17, 2018 9:06 am    Post subject: Re: Download Reply with quote
WOW. What a revelation. Shocked
Presumably most people have heard of the initialism RTFM, but chose to ignore it on occasions, then bleat that 'it doesn't work' because they don't RTFM.
Rolling Eyes
PostPosted: Sat Mar 17, 2018 9:41 am    Post subject: Reply with quote
99% of the time manufacturers don't consider speed cameras when speccing their head units.
As posted above, normal 'navigate to' POi's work OK.
If you do manage to get reliable advance warnings of cameras well done as it's usually a fudge.
geejay38
PostPosted: Mon Mar 26, 2018 10:19 am    Post subject: Reply with quote
Agreed the Nissan Connect System is poor.
There has not been any updates of their Speed Camera Data since September 2017 so I always keep my iPhone and SD card CameraAlert Database up to date.
Garmin Dash Cam 45
geejay38
PostPosted: Sun May 20, 2018 8:04 am    Post subject: Reply with quote
Still no updates from Nissan so may have discontinued this service.
For some reason time stamp is one hour too early Exclamation
Garmin Dash Cam 45
PostPosted: Sun May 20, 2018 8:46 am    Post subject: Reply with quote
Time stamp of what? BST/GMT setting?
PostPosted: Sun May 20, 2018 9:13 am    Post subject: Reply with quote
Yew, it's your forum time settings that need changing.
I'll bet you're set to GMT.
If you leave it till the end of October it will fix itself though
geejay38
PostPosted: Sun May 20, 2018 9:51 am    Post subject: Reply with quote
Thanks Kremmen.
I’d assumed the time would change automatically in Spring and Autumn, as it does in the other Forum I belong to.
I have done update now.
Garmin Dash Cam 45
Page 2 of 3
